Entertainment Display issue
Old May 21, 2021 | 08:56 PM
Big Mak's Avatar
Big Mak
New 2021 F350 Lariat.
The ED is sometimes just black. Nothing. Radio works and cameras display but everything, black.
Shut truck off. Start back up. Black. Come back 30 min later, then it works again.
In other words, its not a repeatable scenario so how the hell do I get this warranty work done when it's not repeatable consistently?
Anyone else had this issue?
Old May 21, 2021 | 09:17 PM
ford390gashog's Avatar
ford390gashog
Have you performed a master reset? If so then it sounds like you have a failed APIM.
Old May 21, 2021 | 09:53 PM
cpobst's Avatar
cpobst
I had a similar issue. I ended up taking my truck to the dealer while it was happening. They had to capture it for warranty reasons while it was happening. At first they thought it was the APIM then they did a complete software reload and that fixed the issue.
Old May 21, 2021 | 11:12 PM
4wd6.7L's Avatar
4wd6.7L
I've had it happen one time in the past 2 years. Maybe try a reset, like mentioned above, and check to see if there are any updates available.
Old May 22, 2021 | 06:58 AM
Big Mak's Avatar
Big Mak
Thanks all.
will try that this afternoon.
Old May 22, 2021 | 07:01 AM
encmerk's Avatar
encmerk
You’re probably holding one of the best troubleshooting tools you can own in your hand. Take video to show the technicians. They still need to see it in person, but it can help them verify or lead them down a path toward resolution.
Old May 22, 2021 | 07:42 AM
B-737's Avatar
B-737
This has happened to me twice, turning the truck off and back on has fixed it. My next step would be re-booting sync using pwr + fwd seek. I cant induce the black screen, both times were random. But in both instances ive found that I jumped in the truck and put it in reserve in almost the same instant, I didnt give it a few seconds to boot up.
Ive also found that if I dont give the sync system a few seconds after starting the truck before moving, that when I back up to my trailer, I can't "zoom in" on the hitch view, the zoom button doesnt work. If I give the system a few seconds after starting it will work every time.
Old May 22, 2021 | 07:53 AM
Mlarv's Avatar
Mlarv
I had this happen last week. While I was driving it went black and then came back on in around 5 minutes. I figured it got a download from Ford for the SYNC system.
As stated above video it when it is happen and have the service writer leave the ticket open along with sending in the video. This should get the ball rolling on the fix.
Old May 22, 2021 | 05:27 PM
zekes66's Avatar
zekes66
Mine has been doing it since the last update. I do a soft reset and it fixes it. ( Power + track forward )
Old May 22, 2021 | 08:52 PM
VanGo3's Avatar
VanGo3
Sounds like Ford is still cramming in tech that ain’t ready for prime time.
Old May 23, 2021 | 06:47 AM
encmerk's Avatar
encmerk
This might help.
File Type: pdf
Old May 23, 2021 | 06:49 AM
Big Mak's Avatar
Big Mak
I did a reset and low and behold, Ford Pass had an update. After the reset and update on phone, no black screen issues yesterday!
Thanks all!
Old May 23, 2021 | 08:03 AM
B-737's Avatar
B-737
not really, sync 3 has been around for about 14 years.
Old May 23, 2021 | 08:10 AM
GABAR's Avatar
GABAR
Ummmm nope.
SYNC 3 has only been around for 7 years.
Old May 23, 2021 | 08:16 AM
B-737's Avatar
B-737
ok call it 7-10-14 whatever, my point is, it's not new by any stretch.
https://en.wikipedia.org/wiki/Ford_Sync#Sync_3
