Reading around this forum, there was a thread where you said there maybe some fox shocks in devolvement. Did those ever come to be a think or are the Bilstein's still the way to go?
no, couldn't get them to do what i wanted at the price.
Thanks. clearance is tight but it clears. Also tires do not hit the leaf springs. Ideally an extra two inches of lift would probably have cleared with no trimming.
What's the offset on your wheels? I'm looking to do the same thing.
Thanks
Thanks for the info. The wheels I'm looking at have a -18mm offset. That should give a little more "poke" but clear the fender liners a little more (6mm). What say Ya'll?
Not positive, but that little bit more poke out may put you more into the bumper or sheet metal at the rear of the wheelwell......?
Hmm? You may be right. I wish I could mount em' up and compare, but that's not gonna happen. I can order the Method wheels with the -12mm offset. Maybe I should go with what seems to work.
Thanks
