Temperature Gauge Questions
Old May 20, 2021 | 10:50 AM
jerryparks's Avatar
jerryparks
Hey everyone.
I have a 5.8 F250, I've noticed the temp gauge gets a bit higher than my old trucks did, but they were different engines. It hovers between the M and A of NORMAL on the gauge (M around town, A doing 70 on the interstate).
Is this about right? My truck is a service truck and the GVW is about 8k.
What is the temperature at various points on the letters?
Where can I install a water temp gauge so I can watch it better on this engine?
Thanks!
Old May 20, 2021 | 11:45 AM
SFaulken's Avatar
SFaulken
Could be any number of things. Clogged radiator or block, weak water pump, thermostat not opening all the way, fan clutch going to hell. I'd honestly start with getting in there and externally washing the radiator to make sure the fins aren't all full of crap, it can certainly happen.
As far as installing an aftermarket gauge, on a 351, there should be an extra port in one of the intake manifold water jackets, or you can do a Tee off the same port that the factory sensor goes into.
Old May 20, 2021 | 01:02 PM
Johnny Paycheck's Avatar
Johnny Paycheck
There is no precise meaning to where the gauge points. It’s a fake gauge just like the oil pressure gauge and voltmeter(?) sitting in the cluster.
Even my ‘03 just has a few gauges pointing aimlessly in the middle, more or less. My ‘18 Ram is no different. Some cute gauges without numbers that point about midway. At least I can get actual numbers off the big info screen...
Old May 20, 2021 | 01:42 PM
R&RFord's Avatar
R&RFord
The sender the gauge works off of provides variable resistance based on temperature, which you can test. However, I have found there is a fair amount variability between senders, and thus how the gauge displays. Aftermarket seems to be worse than OEM, but also much cheaper.
My truck currently has a Standard brand sender in it, and once warmed up the needle tends to travel between O and R, so I remember that as the normal area of the gauge. It does seem accurate enough that I can see the temps going up, and then when the thermostat opens the gauge drops a bit and stabilizes.
If you want to know what going on you can install an aftermarket gauge, which work on the same principles, but the gauge is graduated and the sender unit will probably be better made. They make thermostat housings that are already machined to accept a sensor, but you can put one just about anywhere.
As far as the truck running a little warm, could be a lot of things, may just be time for an ignition tune up or to flush the cooling system. Maybe the sender needs to be replaced. Start with the basics and move forward from there.
Old May 20, 2021 | 01:49 PM
R&RFord's Avatar
R&RFord
The temp gauge is not quite as bad as the later oil gauges. The oil gauges and sender setup are deliberately set up as an idiot light, either on or off so as to stop customer complaints about "low" oil pressure. The temp gauge is an accurate display of the sender, it just isn't all that consistent sender to sender.
Old May 20, 2021 | 03:32 PM
My4Fordtrucks's Avatar
My4Fordtrucks
It’s a fake gauge just like the oil pressure gauge and voltmeter(?) sitting in the cluster...
That’s not accurate. In 1989 the oil pressure gauge was turned into a fake gauge. You can convert it back into a real gauge. The temp and voltmeter are real gauges.
Old May 20, 2021 | 10:10 PM
Scndsin's Avatar
Scndsin
Originally Posted by jerryparks
...Where can I install a water temp gauge so I can watch it better on this engine?...
Drill & tap the flat boss on your T-stat housing with appropriate NPT threads for what ever sender you are using.
You can do the same on the intake side of the housing if you feel froggy & want he the temp reading from there.
Old May 23, 2021 | 10:19 PM
TobyB's Avatar
TobyB
Having both factory and aftermarket temp gauges, the factory is consistent.
My 350 runs right between R and M, and the 88c thermostat gives a 200f reading
on the VDO gauge.
The truck warms up a little going up a significant grade with the trailer, and mid- M corresponds to 210f.
Are either truly accurate?
I doubt it. But it doesn't matter too much,
If it ever makes it past mid- A, it's time to slow down, gear down,
and get out of the throttle...
...and then check coolant when it cools off.
whut mine duz,
t
machinist91
Oct 1, 2013 09:56 PM
thordehr
May 7, 2012 04:39 PM
brelandt
Bronco II
Jul 13, 2006 09:03 PM
