Over Treating?
Old May 19, 2021 | 09:50 PM
Justin Longacre's Avatar
Justin Longacre
Over Treating?
Greetings everyone, I have another question...
In regards to treating my fuel with additives, Should I be using PM-22A and PM-23A year round? Or one or the other? I have been using both regularly, regardless of the weather. Another question is if using both, would that contribute to a clogged EGR cooler? I am asking the former because I just replaced said part for the second time in 3 years- this time costing $600 more than the last.
Old May 19, 2021 | 09:56 PM
ford390gashog's Avatar
ford390gashog
Clogged EGR is from cold exhaust Temps normally associated with excessive light loading or long idle periods.
Old May 19, 2021 | 10:01 PM
Justin Longacre
excessive light loading not a problem now.....the truck is going to have to work.....5er weighs a lot and we plan on travelling a lot...
Old May 20, 2021 | 12:08 AM
HRTKD's Avatar
HRTKD
PM-22 and PM-23 is an either/or situation. You shouldn't need to use them both at the same time.
Old May 22, 2021 | 08:46 PM
Claluja's Avatar
Claluja
Pm22 above freezing, and pm23 when below freezing. Not both. They are both good lube for the fuel pump.
Justin Longacre
May 19, 2021 08:53 PM
Mcrafty1
Apr 29, 2016 05:20 PM
martin123456789
Jul 6, 2011 11:55 AM
MudhenGIB
Jun 7, 2010 08:33 PM
