6.0 trans cooler for E99
Old May 19, 2021 | 06:47 PM
tshrager's Avatar
tshrager
Looking to upgrade trans coolers on my E99. Any fittings or hoses that need changed? Plug and play? Thanks
Old May 19, 2021 | 07:03 PM
FordTruckNoob's Avatar
FordTruckNoob
You will need adapters for the ATF lines to connect to the 6.0 transmission cooler. I welded AN/JIC fittings on mine.
Old May 19, 2021 | 08:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The cooler lines on your truck are 3/8". The fittings on the cooler are 1/2".
Old May 19, 2021 | 09:46 PM
jgg123's Avatar
jgg123
I used brass barbed fittings from the hardware store. Did reducing elbows right at the bottom of the rad.
Sealed the threads with loctite 592. Couple fender washers, bit of hose (I used power steering hose) and some clamps for parts.
Remove the grill and ac condenser brackets, install from the top. There is a splash guard and some sort of cross member on the bottom that needs to be removed.
Old May 20, 2021 | 07:39 AM
tshrager's Avatar
tshrager
Thanks for the help. Sounds easy enough!
milehi_350
Mar 2, 2013 12:02 PM
2cylguy
Jan 13, 2010 03:11 PM
midcal48
Sep 11, 2009 07:03 PM
