Inner cv joint leak at diff.
Old May 16, 2021 | 01:54 PM
Norcal1234's Avatar
Norcal1234
4wd High
My 87 f250, I noticed has a click when turning right in reverse , looked under the truck and noticed grease on the cv axle going into the front diff, passenger side. The cv boot looked ok, seems to be coming from where the cv axle meets the front diff. I'm assuming the leak is coming from the axle seal in the diff and need to be replaced? There is also play from side to side on the cv axle, and a little play up and down, how much is normal? Would a bad seal be caused by the amount of play or can a bad joint cause the seal to fail? Thanks for any help
maximusfd
Dec 10, 2013 09:28 AM
cbzdel
May 14, 2012 02:14 PM
PRexcursion
Sep 27, 2011 04:40 PM
sand_fiend
Oct 27, 2010 07:50 PM
pkthomas
Aug 30, 2010 12:59 PM
