Dually valve extentions
Old May 15, 2021 | 05:56 PM
Wing Nut Bert's Avatar
Wing Nut Bert
Anyone use/install these? I've seen solid ones and braided steel. Seems like a good idea.
From the factory, the valve stems on the duals are lined up with one another, which looks like it's gonna make things cramped to fill/ check pressure. Anyone find this? Is it worth getting the outer's rotated so the valves are 180 to each other?
Thanks guys!
Old May 16, 2021 | 12:50 AM
Wing Nut Bert
After some further reading , these seem to be often more problem then solution. Looking at just getting a good Milton chuck/gauge like a 501 and figuring out if that'll do the job.
Old May 16, 2021 | 08:36 AM
quest450's Avatar
quest450
Zero issues with steel braided extensions installed in 2002, constantly airing down for beach camping, makes life much easier
Old May 17, 2021 | 08:38 AM
beachcamperf250's Avatar
beachcamperf250
Look into Cats eye or Crossfire. Depending on who you talk to some love them and some hate them.
Me, I just use an extension when I want to air down/up while going out on the beach, I don't leave them on. I got a good dually air pressure reader that I use for the inside tire, I think it was around $20.
I also did my tires 180 as it makes it easier. Make sure to get metal valve stems.
Old May 17, 2021 | 07:12 PM
Wing Nut Bert
Thanks guys.
They do seem to be a 'gold or garbage' type item. Hard to tell if it's a case of installed correctly vs incorrectly.
I don't beach camp, so won't be airing down. And the new chuck/gauge works easy-peazy, so I think I'm good.
As for rotating 180; I had read many do that. But the wheels on the 2021 F350 are five hole, so I think they'll only line up at one orientation.
Old May 22, 2021 | 07:37 AM
eryoung's Avatar
eryoung
I had nothing but leaking problems with valve extensions with my old 2005,so I never tried them on my 2017
Old Jun 30, 2024 | 09:36 AM
wudwork's Avatar
wudwork
I have read that the steel belts in the 19.5" F450 tires cause problems for TPMS so Ford disabled this functionality in computer. At least in 2023 F450, this is easy to circumvent. THESE GUYS seem to have activated onboard TPMS.
Old Jul 1, 2024 | 08:31 AM
beachcamperf250
I switched to using crossfires on mine a few years back, does a good job and you can tell when your tire is inflated correctly by the easy to read gauge on the outside.
Allows me to air Up/Down from the outside tire.
snorindad
Dec 31, 2020 09:03 AM
rcorcich
Apr 13, 2008 09:12 PM
michigandrake
Offroad & 4x4
13
Feb 28, 2006 07:36 AM
