ZF5 Swap Question
Old May 15, 2021 | 10:55 AM
ProjectFord's Avatar
ProjectFord
ZF5 Swap Question
Hi, I have a 2006 GMC 2500 that I'm putting a mildly built 77 460 in and I'm wanting to go with an 86 ZF5. But I'm having a problem with finding a release bearing that will fit. The inside diameter on the one that came off of it is 1-3/4 and I haven't been able to find one large enough. The only ones I can find are around 1-3/8. Has anyone else had this problem or know where I could find a new throw out bearing. It's 12in clutch and I believe the tranny came out of a F-350 that was original paired to a 460. Thanks in advance.
Old May 27, 2021 | 04:57 AM
RTM's Avatar
RTM
One would think this should be straight forward. Does the small block ZF use the smaller ID? That's the only thing I can think of that would cause the issue.
william16339
Nov 5, 2017 01:34 PM
1980StepSide
41
Apr 25, 2009 01:26 AM
jswisc
Feb 14, 2008 11:08 AM
BinderBoy
Mar 15, 2000 02:56 PM
