Engine swap. 81 f150 351W
Does the engine actually shake more or does it "sound" more lopey? If it's more of a sound, when the engine is dead cold start it up and then quickly go out under the hood and run your hand around the manifolds. If you do it quick enough it should not burn your hand. You are feeling for puffs of exhaust from a leak that you may not be able to see, but can feel.
If it is actually shaking, I would suspect a plug wire or a plug. You probably took those off to replace the manifolds? You may have a wire in the wrong place, one of the wires got damaged by pulling on it (very easy to do) or one of the sparkplugs was damaged.
ok thanks I'll try that and get back to y'all. Thanks for all the help
kingone
12-13-2000 09:17 PM
