IFS help needed
Old May 12, 2021 | 01:42 PM
abusek's Avatar
abusek
IFS help needed
I'm looking for a vendor who does a 2" drop spindle and has 5X5.5 hub disk brake setup that would work with the TCI IFS kit. Been waiting on TCI for over 8 months now have the TCI IFS kit installed minus the spindles, hub, brake setup. At this point they still can't give me a date and I have lost all confidence in them.
Old May 12, 2021 | 02:12 PM
52 Merc's Avatar
52 Merc
Does your IFS kit utilize standard Mustang II spindles? Or are they a specially designed part where only the TCI spindle will work with their kit? There are lots of places that make a MII drop spindle. Keep in mind that the original Ford spindle was a forged steel part, so it would be in your best interest to make sure whatever replacement you find is also forged steel, not cast or iron, to make sure it adequately strong. I'd also be wary of anything made by Helix or any of their pseudonym companies.
Another question would be are you sure you want or need a 2" drop spindle? Many people find them to be too low and are happy with the stock height spindle.
5 on 5.5 brake rotors/hubs don't have to be sourced from the same company. Brakes are a separate component from spindles. Here are some known quality options if MII parts will work for you.
https://www.wilwood.com/Spindles/Spi...temno=830-9807
https://www.heidts.com/part/2-drop-spindle-sp-101-k/
These guys will likely have a brake kit for you if Wilwood or Heidt's doesn't.
https://www.mpbrakes.com/
https://ssbc-usa.com/
Old May 12, 2021 | 02:33 PM
abusek's Avatar
abusek
Not sure if the IFS from TCI will accept a standard Mustang II spindle. Trying to find anybody that may know. Just got a response from them, they have the spindles but only ship with the brake assembly installed. They say the problem is
So the answer is, to my knowledge, no there are no other sources other than China…which is the case now for even OEM rotors. Bendix, Repco…all the US brands you recognize, are made in China. From what I’m hearing its going to get worse before it gets better. There will be major shortages for at least 6 months to a year on hard parts coming from overseas.
Old May 12, 2021 | 03:41 PM
F100supercrew's Avatar
F100supercrew
2 " drop
You do not want to use 2" drop spindles with a Mustang II set-up-- go stock spindles with 215 X 75 X 15 tires with coil springs and gas shocks-- did you call Speedway tech line-- Good Luck
Old May 12, 2021 | 05:37 PM
artscott61's Avatar
artscott61
Veteran: Navy
I used a M2 and it is low enough. I sure would not go 2" . I would tell you to come to the F-100 nats this weekend in Pigeon Forge but I see you are a couple more miles out.
Old May 13, 2021 | 11:06 AM
Gicknordon's Avatar
Gicknordon
I will give the opposite opinion and say I love the stance on mine with 2 inch drop spindles, and very rarely rub on any driveways.
Old May 13, 2021 | 12:06 PM
abusek's Avatar
abusek
Thanks Nick, I think your stance, looks good. Also great build, was following it as you did it. You able to keep that thing under control with that 429 in it? I'm just going with a 351w, figure that may keep my speeding down some.
Old May 13, 2021 | 12:37 PM
Old F1's Avatar
Old F1
The 2 " drop is just fine, ... it never hit.
Old May 14, 2021 | 06:09 AM
Gicknordon's Avatar
Gicknordon
Surprisingly, the truck hooks pretty well, and when it does break loose it doesnt get too squirley. It has really only scared me one time, and that was when the road was a bit wet.
Old May 14, 2021 | 08:30 AM
abusek's Avatar
abusek
Anyone wanting to keep up with the missing spindles and brakes look at the following link. New email today showing sent items but the part numbers look wrong again.
https://www.ford-trucks.com/forums/1...project-5.html
Selfie
Old May 14, 2021 | 08:33 AM
EBEAR's Avatar
EBEAR
What size of front wheel-tire are you guys using Nick and Oldf1 . Yours both sit very nice , definitely where I would want them .
Old May 14, 2021 | 10:07 AM
Old F1's Avatar
Old F1
Sorry the truck is sold, 15 x 60 series I think.
Old May 14, 2021 | 10:22 AM
gerrymoe's Avatar
gerrymoe
Look into these guys, they do quite abit. I have them on mine which has a Volare front end. I have no issues with the height.
Fat Man Fabrications,Custom Chassis, Custom Suspensions - Fat Man Fabrication
Old May 14, 2021 | 07:42 PM
56panelford's Avatar
56panelford
Selfie
I like your selfie Andy...
HRTKD
All Things Towing
Dec 19, 2021 02:20 AM
Beto Gray
17
Mar 25, 2021 10:32 PM
Mike.l.allen3
Feb 8, 2021 10:57 AM
CharlieLed
Mar 17, 2009 06:40 AM
Dr4J
Sep 19, 2004 07:40 PM
