Sponsored by: Real Truck
bearing knock
Old May 12, 2021 | 08:30 AM
ibfishing's Avatar
ibfishing
bearing knock
I have a 1999 f250 with a triton 5.4. It has developed a knock upon acceleration. I do not want to buy another truck, it would be a used one and I am not interested in the crap shoot of a used truck. Is this engine worth rebuilding? I would also be doing some up grades while I am at it. I have heard of guys replacing the bearings, the top end seems sound no smoke, good compression. I don't use it a lot mostly trips to the dump and pulling a small trailer for vacations.
Old May 12, 2021 | 02:49 PM
Gyppo Logger's Avatar
Gyppo Logger
What's your budget like? There are some pretty good after market engine builders out there (and some really crappy ones too). And then there's also crate motors from Ford, the more of your own stuff you use the cheaper it will be. Look in to short blocks, perhaps.
Old May 12, 2021 | 03:05 PM
ibfishing's Avatar
ibfishing
Thanks I am looking into all the options. I have looked at rebuilt both short and long blocks, the shipping makes it speedy but that may be the way I have to go!
Old May 12, 2021 | 03:48 PM
ford390gashog's Avatar
ford390gashog
Most of the time you find out the 5.4 isn't able to be rebuilt. It starts easier to order a reman from Ford or Fraser engines. It often takes 3 or more full engine cores to build a reman modular engine. The heads are prone to cam wear and the cranks are often past spec especially if a rod is knocking or the thrust bearing has eaten itself.
tiredtrucker
2009 - 2014 F150
Aug 19, 2017 11:52 AM
northernredneck93
1997 - 2003 F150
Feb 20, 2013 04:50 PM
adam10
Feb 22, 2012 03:17 PM
Jerky38
Feb 15, 2004 01:11 PM
