Advice on 5TH Wheel Prep Pkg
Old Sep 9, 2024 | 06:37 PM
  #46
4wd6.7L's Avatar
4wd6.7L
Originally Posted by lcseds
A dealer near me orders F450's with no 5th wheel/Gooseneck prep kits. Bizarre.
Pickups? I could of swore the prep kit was standard on all F-450 pickups and wasn't aware of any delete option for it.
  #47
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
Originally Posted by 4wd6.7L
Pickups? I could of swore the prep lit was standard on all F-450 pickups and wasn't aware of any delete option for it.
Was going to post the same thing....
maybe on a C&C.....
Old Sep 9, 2024 | 06:47 PM
  #48
Spartanfan23's Avatar
Spartanfan23
Trailering
I didn't add it to my '22 build and then 18 months later we purchased a 5th wheel. I ended up adding the B&W Turnover ball system, which works great. In hindsight I would have saved money with the factory setup. Drilling a 4" hole in your truck bed is nerve-wracking!
Old Sep 9, 2024 | 07:23 PM
  #49
PatrickStapler's Avatar
PatrickStapler
Amen! When I installed the B&W TOB on my ‘15, I must have measured it at least six times before I drilled it.
Old Sep 10, 2024 | 09:08 PM
  #50
medinapool's Avatar
medinapool
3rd Gear
Thanks for all the replies. One last question, The trucks I am looking for are 6 foot 8 inch beds. If I get a newer 5th wheel camper, Will I need a slip hitch? I have heard both answers. What hitch to get? Thanks
Old Sep 10, 2024 | 09:57 PM
  #51
bpounds's Avatar
bpounds
Most modern fifth wheels do not absolutely need a slider hitch, because the corners are mitered off for improved clearance. Beyond that it becomes a matter of preferred level of safety from a cab collision. Opinions differ on that.
Old Sep 11, 2024 | 06:01 AM
  #52
senix's Avatar
senix
I would recommend a slider for those really tight campgrounds, otherwise you would be fine with a little practice to know your specific limits.
When getting the 5er you will want to practice in am empty lot for those limits and a few practice backing ups. they dont behave like a TT or an like a flatbed with the tires more to the rear.
Old Sep 11, 2024 | 07:34 AM
  #53
Ry Guy's Avatar
Ry Guy
Originally Posted by medinapool
I am looking at an opportunity to buy an F250 Lariat. It has low mileage and appears to be a very good deal. 1 owner and good carfax report. The only issue is it has the camper package but doesnt have the 5th wheel package. I am looking at a small 5th wheel. Only 8000 lbs. So my question is this, would you pull the trigger and buy the F250 and just add the 5th wheel package at the dealership? I am told they will install it for $1400.
I would just buy it from Ford and install it myself and save $700. It's pretty easy to do and can be done in ~1 hour. The only part that you would need another person to help with is lifting the aluminum box off and back on. It's really light, I've done it before.
https://www.fairwayfordparts.net/oem-parts/ford-17-thru-22-super-duty-oem-ford-5th-wheel-gooseneck-hitch-prep-package-lc3z5f057a?srsltid=AfmBOoohLbP07NgLimZ0qYjM6n4Ybln fCKkJOxJEQ1UYgTlq-030KrWy
Old Sep 11, 2024 | 08:16 AM
  #54
NeverboughtanFseries's Avatar
https://www.youtube.com/watch?v=Zvf5Y4DWySo&t
about an hour LOL.
Old Sep 11, 2024 | 08:18 AM
  #55
Ry Guy's Avatar
Ry Guy
Originally Posted by NeverboughtanFseries
about an hour LOL.
You alright? I have done it. Edit: Granted, I've helped others do it before so I admit that having the experience doing it before helps. The guy quoting 3 hours in the video is doing it by himself.
Old Sep 11, 2024 | 09:57 AM
  #56
speakerfritz's Avatar
speakerfritz
Originally Posted by PatrickStapler
Possibly, this is what I'm talking about...
the one that came with my 2019 f-450 looks like this
Old Sep 11, 2024 | 11:02 AM
  #57
johndeerefarmer's Avatar
johndeerefarmer
I have been using the B&W's since 2005. I have installed several myself. The first one I was too cheap to buy a 4" hole saw so I cut it with a saber (jig) saw and filed the edges.
I prefer them for several reasons. One I like the locking pin that holds it on. Not impressed with the little ***** on each side of the others that are supposed to hold it in.
Second I like and use the 4" extended ball as far as I know B&W is the only one that makes one
f350ktm
Feb 26, 2018 12:20 AM
DDT11
Dec 9, 2017 02:19 PM
Pokiejoe
6.7L Power Stroke Diesel
Apr 10, 2017 10:15 PM
gernest2
Jul 28, 2011 12:37 AM
Dual Liner
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sep 17, 2010 09:18 AM
