Sponsored by: Kumho
Dually Spacers
Old May 11, 2021 | 08:53 PM
coalminer's Avatar
coalminer
Dually Spacers
I’m trying to figure out what is the bolt pattern and hub bore size for my 2020 f350 dually. I know all the stories about spacers being bad and so on but I’m still going to use them so I can run 37’s on stock wheels. Thanks in advance
Old May 12, 2021 | 04:40 PM
coalminer's Avatar
coalminer
Guess nobody knows if it is 8x200 or 8x170
Old May 13, 2021 | 04:55 AM
JWA's Avatar
JWA
DIY answer: Lug Spacing Measurement
Old May 18, 2021 | 06:17 PM
ApesGarage♡F~250SD's Avatar
ApesGarage♡F~250SD
Hope this helps
Bolt (lug) pattern PCD 8x170
Stock wheel offset 34mm
center bore (hub bore) 124.9 mm
lug nut thread size M14 x 1.5
Old May 21, 2021 | 09:56 AM
mrdanielcruz's Avatar
mrdanielcruz
Do you aftermarket dually wheels installed?
ufvj217
Nov 28, 2022 01:47 AM
thedieselkid
Dec 16, 2011 01:28 AM
AquaSun
Nov 29, 2006 02:24 PM
dj_mrbones
Mar 9, 2005 01:34 PM
