Whos headers?
Old Oct 29, 2003 | 11:13 AM
dkaska77's Avatar
dkaska77
Whos headers?
I looking to put some headers on my 302 efi. Just lookin for some advise as to what to buy or what to look for.
96 F150.
Are the HP gains noticable?
Old Oct 29, 2003 | 12:52 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Check on the type of header also. Headers are about scavenging.
Old Oct 29, 2003 | 02:42 PM
Hit Man X's Avatar
Hit Man X
Well you got three kinds:
Stock replacment (least power gains). Easiest to install. Usually have small primaries and stock 2" collectors. Better than new manifolds.
Mustang shorty (more power gains). Need a custom y-pipe to run. Mustang shorty headers are a dime/dozen around here. Bigger primary tubes than stock replacments. Bigger collectors around 2.5".
Long Tubes (largest gains). Needs custom y-pipe. A tad harder to install. Big collectors 2.5"-3". Bigger primary tubes than stock replacments too. Make considerably more low end grunt.
I started with just a Flowmaster. Then to high flow cat and Flowmaster. Then switched from stock maifolds with high flow cat and Flowmaster to Mustang shorty headers with high flow cat and Flowmaster. Then to Hooker Longtubes with high flow cat and Flowmaster. Then hacked the Flowmaster out for a Mangaflow. Each with increasing power.
How much are you looking to shell out?
Old Oct 29, 2003 | 03:33 PM
dkaska77's Avatar
dkaska77
I've got a flowmaster Muff. Just lookin to get new headers. Tryin to figure whats gonna give me the gains for my buck.
Want to go with Shortys but which ones. Ceramic? Wrapped?
Which ones?
Old Oct 29, 2003 | 03:44 PM
fordtruckinsml's Avatar
fordtruckinsml
Hit Man,
I have a Gibson Split rear exhaust, and I want to get a high flow cat also. I was just wondering if you felt a difference from replacing the stock cat with a High Flow. Thanks
Old Oct 29, 2003 | 04:42 PM
Hit Man X's Avatar
Hit Man X
fordtruckinsml...I gained a bit of power, along the 6-9rwhp area, but the sound gain was incredible! Was it worth the $40 for the cat and $20 to install...YES. Once you get a bigger cat you will want headers too.
dkaska77...long tubes set me back $200 or $250, I can't (and don't care to) seem to remember the cost. They were worth it for sure. I spent ~$125 hooking up the LT's to the rest of the exhaust system I had.
Stock replacments aren't worth the money in my opinion. Close to $200 for 6-8rwhp sucks in the cost per hp area.
If you have to have shorty headers I'd get a set of unequal length Mustang shortys. They have 2.5" collectors (usually) and will make more power. You'd still need a custom exhaust made.
What do you have set aside to spend?
Old Oct 29, 2003 | 05:00 PM
Vanhecht's Avatar
Vanhecht
i was under the impression that you can get headers from lets say, bassani, that will bolt up to the original y pipe, and are equal length...thats one of the reasons i got the direct bolt in bassani y pipe and high flow cat
Old Oct 29, 2003 | 05:06 PM
Hit Man X's Avatar
Hit Man X
You can but they still probably have 2" collectors...kinda small. At least the drop in replacements I have seen have 2" collectors.
Equals don't make too much more power than unequals either.
Old Oct 29, 2003 | 07:51 PM
84-250's Avatar
84-250
Hit Man X
how are the hooker longtubes holding up?
how far do the headers extend from the back of the engine, measure from the beginning of the trans to the end of the headers?
Old Oct 29, 2003 | 08:09 PM
Hit Man X's Avatar
Hit Man X
Originally posted by 84-250
Hit Man X
Pretty well. I used copper collector gaskets and composite header gaskets and leak free for months now. I also used ARP 12 point bolts up top with a dab of blue Lok-Tite. Torque them in at 15ft-lbs. I let the vehicle sit for ~12 hours before driving so the Lok-Tite can set.
I'd say they come back 6-8" from the back of the motor to where the collectors end. I can't measure them today as I am not with the truck currently...
Old Oct 29, 2003 | 08:29 PM
84-250's Avatar
84-250
how are the gaskets and bolts that come with the headers?
did you get the coated or the black painted ones?
Old Oct 29, 2003 | 08:49 PM
Hit Man X's Avatar
Hit Man X
The gaskets and bolts are okay. I just don't feel like replacing that stuff again...hence why I picked up the more expensive install bits.
Mine were black. I stripped them and painted them with VHT 1500*F paint. I forgot to let the vehicle idle for 20-30min to cure the headers so some of my paint is peeling off.
If you paint them...just install as normal and start the vehicle then allow it to idle for a while to cure the paint.
Old Oct 29, 2003 | 08:54 PM
84-250's Avatar
84-250
what about the o2 sensor, is there a bung or is yours a custom install
Old Oct 29, 2003 | 09:10 PM
Hit Man X's Avatar
Hit Man X
Custom installed... hopefully these pics will work:
https://www.ford-trucks.com/user_gal...=17949&width=0
https://www.ford-trucks.com/user_gal...=17950&width=0
https://www.ford-trucks.com/user_gal...=17939&width=0
https://www.ford-trucks.com/user_gal...=17937&width=0
