Axle ratio
Old May 11, 2021 | 02:34 AM
jsvec2000's Avatar
jsvec2000
Axle ratio
I have a 2002 Ford Excursion 7.3, I have factory 3.73 gear with stock tire 265/75R16.
I looking to getting better fuel mileage thinking of changing the rear gear to 3.42 or 3.55.
I don’t do much towing maybe twice per year with 5000lb max what can I expect mileage change ?
Is it worth doing.
Old May 11, 2021 | 04:01 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If not towing most of the time I doubt you will realize any gains. The cost of install vs MPG reward just isn't there. Even less likely if your Ex is 4X4 as the cost to re-ring is double.
If you have the parts for free and do all the work yourself you might come out ahead.
For best MPG I'd focus on tire diameter.
Also a big factor for a stock unmolested truck is the up pipes. The OEM design wears over time and loses boost, which kills MPG and HP. If your uppies are OEM I bet your best ROI is in upgrading to bellowed uppies.
Old May 11, 2021 | 04:36 AM
jsvec2000's Avatar
jsvec2000
Thanks for your advise. I have done the up-pipe kit and 4” exhaust several years ago, plus I running Hydra Chip 80hp Daily Driver the rear end is starting to make a little whirring noise so I’m going to have to change it at some point that the only reason I’m thinking about it. 65% of my driving is highway/expressway what size tire would you suggest?
Old May 11, 2021 | 06:32 AM
udsuth78's Avatar
udsuth78
Here is a link to a gear ratio calculator. You can play around with different ratios and tire sizes for your desired rpm. Might help you figure out a good combination.
https://www.tremec.com/calculadora.php
Old May 11, 2021 | 06:34 AM
FordTruckNoob's Avatar
FordTruckNoob
If you don't go off road, an air dam under the front bumper to block air from going under your vehicle might be the most effective way to improve your gas mileage. This is particularly true if you spend a lot of time at highway speeds. An air dam that goes from the bumper down to as close to the road without getting dinged to smithereens is best.
Old May 11, 2021 | 10:56 PM
jsvec2000's Avatar
jsvec2000
That's awesome it will help a lot. Thanks
Old May 12, 2021 | 06:11 AM
Bently_Coop's Avatar
Bently_Coop
Here's a thread on air dams/valances for our trucks.
https://www.ford-trucks.com/forums/1...t-air-dam.html
wgb
1966 - 1977 Early Broncos
Nov 1, 2019 12:58 AM
AZTod
Jun 24, 2019 08:19 PM
Garymcd
Jan 20, 2013 07:09 PM
0273
15
Mar 3, 2009 02:45 PM
JasonMerrick
Mar 13, 2002 06:11 AM
