Super Duty Adaptive Steering
Old May 11, 2021 | 08:50 AM
Smindustries's Avatar
Smindustries
Originally Posted by C12H24
You have to be careful about what people are referring to. Many believe adaptive steering is the lane departure feature. Adaptive steering only speeds up the ratio at low speeds. It adjusts to "normal" steering at higher road speeds to prevent the sneeze reaction from putting you in a ditch. There are differences in trucks too. 2019 and earlier used hydraulic steering assist, while later trucks are electric assist. They have a different feel. I have adaptive in my 2018 and it's great having that assist in parking lots. My highway feel is very nice.
Incorrect.
Originally Posted by Ford Press Release
DEARBORN, Mich., Sept 22, 2016 – From carpool drivers to work crews, folks around the United States are about to discover the only steering wheel that works as hard as they do.
Adaptive steering technology makes the all-new Ford F-Series Super Duty pickup and Ford Edge SUV easier to steer at all speeds.
Despite the industry shift to electrically assisted steering, an overwhelming majority of new vehicles sold today have fixed steering gear ratios. Fixed steering ratios are always a compromise between providing steering quickness and maneuverability at low speeds, while offering comfortable vehicle response at high speeds. Ford has been awarded eight patents for the technology and 11 more have been filed.
Class-exclusive adaptive steering for the all-new Super Duty and Edge removes these compromises and reduces driver fatigue – especially at low speeds.
The system – all contained in the steering wheel itself – has an electric motor, a small computer and a gear unit. Based on driver input and vehicle speed, adaptive steering can add or subtract rotations to driver input at the steering wheel. Up to one full revolution can be saved at low speeds when steering lock-to-lock.
At low speeds, the system increases the angle of the front wheels as the steering wheel is turned – resulting in the driver needing to steer less to maneuver, explains Lodewijk Wijffels, Ford adaptive steering technical specialist. “At high speeds, the ratio is changed in such a way that vehicle response is more relaxed, more precise, and smoother than without the system,” he says.
Adaptive steering contributes to delivering the best ride and steering of any Super Duty ever, with improved responsiveness and control. The truck features a specific setting for engaging tow/haul mode that further optimizes how Super Duty and trailer react to steering input.
Adaptive steering made its debut on the 2016 Ford Edge Sport, which has driver-selectable normal and sport settings. Adaptive steering is optional on the 2016 Ford Edge Titanium.
https://media.ford.com/content/fordm...echnology.html
Old May 11, 2021 | 08:59 AM
RubenZ's Avatar
RubenZ
Exactly,
So it does function at high speeds too like I had thought. Guess I did know what I was talking about. Bottom line. I didn't like it and a lot of others don't as well. It's certainly not worth the high price for it. Again its all relative and that's how I feel. Like others have said, you really need to drive it yourself to make sure its what you want. Never in my years of driving vehicles (ranging from 80's chevy's to modern vehicles) have I said damn I cant turn this truck lol.
Old May 11, 2021 | 09:05 AM
Smindustries
Originally Posted by RubenZ
Exactly,
No, you did not. You made factual errors about certain model years having a different, hydraulic, assist system. That's what was incorrect.
Your opinions about worth, value, or merit of the system are neither correct nor incorrect.
Old May 11, 2021 | 09:26 AM
4wd6.7L's Avatar
4wd6.7L
Exactly,
Well sorta, yes it is not completely out of play at higher speeds but your assessment of it increasing sensitivity and providing more feedback would be incorrect, or in other words not typical of the feature. In fact there are others who have had negative reviews of it that complain about the apposite feel at highway speed.
At highway speed the sensitivity(ratio) is not increased but rather the opposite would be true. At higher speeds it becomes as described in the other post as more "normal", and under some circumstances even less sensitive to driver input.
Your experience is yours, but not to be expected of the option. I do agree that test driving two trucks, one with and one without is the best course of action before deciding. When test driving the trucks, if the Adaptive equipped truck has the electronic steering assist, then for comparison sake the non Adaptive truck should as well (not all have it). That will make for a true comparison as the electronic steering assist adds another layer of feel to the truck.
Did you test drive a truck with Adaptive steering and one without? Did they both have the electronic power steering overlay?
Old May 11, 2021 | 02:48 PM
406f150's Avatar
406f150
I have it on my 2017 and the only other superduty of this generation that I've driven had it too. I'd have to drive one without to really see how much difference it makes, but between it and my wide track front end I haven't met a parking garage or lot I can't get into yet!
Only issue I have with it is I can't do the Raptor steering wheel swap to get paddle shifters.
Old May 11, 2021 | 05:24 PM
2019er's Avatar
2019er
When I bought my truck, I thought it meant lane keep assist, which I discovered on a Chevy rental. Meaning, if you get too close to the line, it will actively gently steer you back into your lane, while also vibrating your seats and sounding an alarm tone to wake your *** up. I thought it was a pretty sweet feature. Also, it somehow could tell if you were falling a sleep, and start raising hell to move the steering wheel to let it know you weren't. Say what you want about this fancy ****, but I've driven tired and just been lucky nothing happened, where this could actively save you and/or others.
Old May 11, 2021 | 05:33 PM
4wd6.7L's Avatar
4wd6.7L
I imagine it didn't take long for you to find out that you got no such feature.
Ford doesn’t yet offer any feature like you described on the Super Duty. Lane keep alert is all you can get. Vibrates the steering wheel but doesn’t make any steering corrections.
Old May 11, 2021 | 07:57 PM
cat-alac's Avatar
cat-alac
Had a 17-18-19 without, then 20 and 21 with, I’m not sure what it does seems no difference to me, thinking once you’re used to one way or the other it’s a mute point.
Old May 11, 2021 | 08:06 PM
09FX-4's Avatar
09FX-4
Would not buy one for my personal use without it.
tkdcipsi
Mar 7, 2021 08:42 AM
Bill Tex
Feb 3, 2020 07:10 AM
m-chan68
Ford Truck Parts for Sale
Feb 25, 2018 01:23 PM
BII Plow Truck
Apr 30, 2017 11:32 AM
Biga$$truck
Mar 14, 2008 01:13 PM
