Sponsored by: Real Truck
2000 Ford Excursion electric seat switch
Old May 9, 2021 | 08:15 PM
Griff62's Avatar
Griff62
Trying is figure out why seat won’t go forward. The reclining trick didn’t work. I took the seat switch out & opened the case to clean the connectors & out pip 1 white pin & a spring. I figured where the pin goes but no idea where the spring came from. Any help
Old May 10, 2021 | 05:57 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. If you take your question to the Excursion sub-section, you'll probably get more help then you can handle. On the top left of your screen, click on, "Forums". Scroll down to "Super Duty/Heavy Duty". Click on it and you'll find the Excursion sub-section. They are the experts.
Don't forget to check out your state chapter too.
Old May 10, 2021 | 09:09 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
x 2000
New Member Introductions
Apr 16, 2013 02:22 PM
Pat Ricchiuto
Jan 5, 2010 03:56 PM
racermom167
Jul 24, 2006 02:03 PM
