I’ve looked online but ever since I did nav in motion in forscan on my 2021 f350 sbcc lariat the zoom on the 360 doesn’t work. Me being new at forscan I didn’t save any of the original numbers does anyone know what the original numbers need to be on the nav to take it back to stock
Same thing happened to me and my nav settings were different so i just put it back to normal/
do you know what the normal values are or how to get back to stock i forgot to save it all before changing
Yours might be different then mine but i found a ford website that if you enter your truck vin it will give you all the factory codes for stock values so i downloaded and saved mine for any future issues.
Nevermind I got it your a life saver thanks! When you changed it to nav in motion did it stop letting you zoom in on the camera ?
Yeah no problem i would save that file just incase something else changes. I put it back to stock within minutes of it not acting like stock so I didn't check everything it changed
