TCM MODULE ?
Old May 9, 2021 | 10:09 AM
Hammered29's Avatar
Hammered29
TCM MODULE ?
I have a 2021 F350 Platinum and am trying to find the TCM module. Anyone know why it doesn't show in the configuration screen? I want to do the relearn procedure for changing tire size in Forscan.
Old May 9, 2021 | 10:33 AM
4wd6.7L's Avatar
4wd6.7L
Isn't tire size changed in the BCM?
Are you trying to reset the adaptive learning tables in the TCM?
Old May 9, 2021 | 10:47 AM
ford390gashog's Avatar
ford390gashog
You are missing modules, are you using a adapter with a switch? Are you allowing forscan to load a previous saved profile?
Old May 9, 2021 | 11:11 AM
Hammered29's Avatar
Hammered29
Yes,I changed size in BCM.I Am trying to relearn TCM after changing tire size to clear wrench.
Old May 9, 2021 | 11:13 AM
Hammered29's Avatar
Hammered29
Yes,Iam using adapter with switch.. Not sure what you mean about loading previous file.
Old May 9, 2021 | 06:54 PM
ford390gashog
When you first try to connect, forscan will ask if you want to load previous saved vehicle. Select no, it will then ask after it looks if the device has a switch. Select yes to that question and it should find all the modules.
Old May 9, 2021 | 06:59 PM
Hammered29's Avatar
Hammered29
Ok,thanks! I'll give that a try in the morning.
Old May 10, 2021 | 09:02 AM
Hammered29's Avatar
Hammered29
When I select "no" to load previous data,I get message saying unable to connect. Ignition is on. I'm stumped for what to do.
Old May 10, 2021 | 09:08 AM
Hammered29's Avatar
Hammered29
Old May 10, 2021 | 11:17 AM
Hammered29's Avatar
Hammered29
I GOT IT!! Not really sure how. I deleted profile of the truck then tried to reconnect with the reader that has m/h switch. Would not connect. Then tried my Bluetooth reader and it connected and showed the TCM. Did relearn on TCM and the wrench light is gone!
Old May 10, 2021 | 11:32 AM
ford390gashog
The switch is in the wrong position, flip the switch.
Old Sep 19, 2023 | 08:20 AM
C0reCollector's Avatar
C0reCollector
3rd Gear
I'm using the OBDLink MX Wifi adapter (they no longer make this version) and I don't see any TCM module. There is no switch on this adapter but it's supposed to support TCM. I have a 2023 F150 Powerboost and have successfully reprogrammed items in other modules. Could it be that the 2023 F150 XLT Powerboost doesn't have a separate TCM module? Perhaps everything is in the PCM module now?
randre
Dec 29, 2023 11:57 PM
Dale Massey
Aftermarket Products
Jan 31, 2019 10:14 PM
txazguy
6.7L Power Stroke Diesel
Mar 24, 2017 04:47 AM
forkliftjoe
Feb 13, 2017 04:22 AM
04F-250mark
Mar 7, 2012 11:32 AM
