No head lights
Old May 8, 2021 | 12:06 PM
lil'GreenExplorer's Avatar
lil'GreenExplorer
No head lights
When I turn my head lights on (1976 F150, with a 360) my head lights don't come on but the high beam and signal indicators on my dash come on. 12V is getting to the head light sockets but on all three contacts and there is what looks like a little ground wires by the head lights that has 12V on it.... any ideas of where to start looking?
Old May 8, 2021 | 02:28 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Maybe you had both bulbs burn out, or your headlight switch is bad?
Old May 8, 2021 | 07:52 PM
lil'GreenExplorer
possibly the switch, but I measure the light sockets and appear to be getting 12V on all three contacts
Old May 8, 2021 | 08:08 PM
77&79F250's Avatar
77&79F250
Then you have a rarity and have burned out both high and low elements.
Old May 8, 2021 | 09:43 PM
lil'GreenExplorer
high and low on both sides? that wouldn't explain the 12V coming out the ground wire
Old May 8, 2021 | 09:45 PM
77&79F250's Avatar
77&79F250
Well that was a SWAG anyway.
Old May 8, 2021 | 10:01 PM
FuzzFace2's Avatar
FuzzFace2
How are you measuring the volts at the plug?
The only way to do it is to unplug all head lights before you measure volts at the plugs.
I think you said you can follow the ground wires to the plug but first test light to (or meter) to ground and then check the other 2 contacts.
1 should have power on low the other on high.
Then I would test the 2 contacts with the ground and see what you get.
BTW power comes out of the head light switch to the dimmer switch for high & lowto the head lights.
Dave ----
Old May 10, 2021 | 08:43 AM
79F150400M's Avatar
79F150400M
Had similar/same issue on my 76.....it was the dimmer switch. Twelve bucks at O'Reillys and I was back in business.
Old May 10, 2021 | 10:26 AM
mudbogger2's Avatar
mudbogger2
If you have 12 volts at the ground wire with the headlights still plugged up then you have a bad ground. Voltage is getting to the headlights and looking for a good ground. Try adding a ground from the battery to the radiator support and see what happens.
christurney77
1947 and Older Ford Trucks
Feb 1, 2013 12:47 PM
RLA
44
Dec 11, 2011 12:40 AM
A&Asuperdog
Sep 17, 2009 06:43 PM
