Top dead center???
Old May 6, 2021 | 12:58 PM
Dustin Armentrout's Avatar
Dustin Armentrout
Top dead center???
So i got the new IP in as well as new injectors, etc. When advancing or retarding the IP, is it necessary to rotate the motor to TDC everytime you move the IP? Ive looked for a while but couldnt find anything specific to that motion in the process. Yes i know i had to do it initially, but is it required everytime i mess with the IP? And not just for advancing or retarding either. Am i supposed to do that after any kind of a mechanical adjustment? I know i dont need to do it when adjusting the throttle cable, idle screws, or the fuel level with the internal screw. But everything else? Thank you in advance.
Old May 6, 2021 | 04:30 PM
tecgod13's Avatar
tecgod13
nope, only when lining everything up
Old May 8, 2021 | 11:14 AM
Tumbleweed1972's Avatar
Tumbleweed1972
You need to set it to TDC when bolting up the pump? I never knew this and have never done it. Why, what does it do? The pump has got a dowel to line it up in the right bolt holes.
Old May 8, 2021 | 07:43 PM
90Ford73's Avatar
90Ford73
I think tecgod means if you pull the pump with the gear attached. As for just changing the IP, your correct. Line up the pump slot with the gear dowel n bolt it together.
redsadam
Jul 14, 2013 01:22 PM
BomerFett
17
Jan 5, 2012 03:38 PM
LSO1123
13
Jul 30, 2011 10:42 AM
dragonfire317
Sep 7, 2007 10:09 PM
katdon2001
Jan 31, 2005 08:46 PM
