Changing gear ratios on a 2017 F150?
Hello,
I've owned my F150 for about 4 months now and tow regularly with it, and have found the 3.31 rear end gear ratio paired with the 5.0L is kinda lacking with the hills we have here in Eastern Pennsylvania. Has anyone done a gear set swap in these trucks? Any recommendations for a company that sells a kit?
Another thing is what gear ratio should I go to? Stage 3 offers a 4.11 gear ratio, but I feel that that would be a little too low, 3.73 would probably be the overall sweet spot, and another thing I would like to do is retain the electronic locker.
Thanks in advance.
Thanks in advance.
The following users liked this post:
Your tires are 32.1” tall. 32.1 x .12 = 3.85. The factory usually rounds up, but lately they have been going way up to your 3.31s to get a higher fuel economy rating at highway speeds. In my opinion, all 5.0s should have come with 3.73s at a minimum.
Given the above simple formula, you could go with 3.73s, but if I was investing in the expense of a gear change I would go with 4.10s. You will get better performance and mileage when towing and in town. Empty on the highway over 60-65 your mileage will take a slight hit. There’s another thread on here that’s relatively recent where a guy went to 4.56 with his 5.0 and he is very happy.
And I never quite understood forsaking better towing capabilities for the sake of a mile or two better MPG, if the increase in MPG with 3.31 is even that good. I’ll probably end up going with 4.10’s and call it good, because the truck just dies on the hills!
In the real world, Force = Mass x Acceleration
Either get a truck with more caboose that can overcome basically pulling its own weight uphill or get an engine that doesn’t need those kinda revs to get up to speed, like a 6.2 Super Duty. The 5.0 is fine revving like that, though.
And to the OP you can keep the e-locker by just changing the ring and pinion. The gear set isn't all that expensive. It's finding a competent mechanic that is VERY experienced in gear setup that won't charge you an arm and a leg. I have never setup a gear set so DIY is out.
If anyone knows of such a mechanic in the north Dallas area, please let me know.
You tube is full of wannabe's....... I have the space and can make the time. Most likely have all the tools needed as well. I was a line mechanic way back in the 70's at Dub Shaw Ford in Ft. Worth.
I have set up a few differentials in my day also, just for myself, and had sucess. I.E. didn’t have any differential problems after the job was done.
