cross member
Old May 6, 2021 | 07:11 AM
lomesome1's Avatar
lomesome1
cross member
My 56 f100 had a 6 cylinder and three on the tree, I want to put a v8 auto in it. My question is does the cross member that had the rear ehgine mounts have to be remover? Thanks
Old May 6, 2021 | 07:02 PM
1956_F100's Avatar
1956_F100
It all depends on how the motor/trans combination sits in the frame. If that is the crossmember I am thinking of , the issue is, it also provides structural strength for the frame rails. Remove it, and the frame rails will have a tendency to twist from the weight of the cab on the front cab mounts. Even standing on the running boards will tend to twist the frame rails. Probably not a coincidence Ford put that crossmember very near the front cab mounts.
Mine was removed to install a 390 and C6 trans. I fabricated another bolt-in crossmember from sq. tubing to recover some lost strength.
oldbleu
16
May 17, 2021 12:44 PM
Ken Bell
May 18, 2013 11:01 PM
bluestang65
Mar 13, 2003 05:33 AM
skip4274
Jul 23, 2001 01:26 PM
