Driveshaft question
Old May 5, 2021 | 05:17 PM
Conanski's Avatar
Conanski
Driveshaft question
Anybody with an E series van that has the aluminum driveshaft, can you confirm that the tapered end goes towards the transmission?
I'm doing U joints on my '11 and I think the thing is assembled backwords.. the tapered end is at the rear axle right now.
Old May 5, 2021 | 06:39 PM
annaleigh's Avatar
annaleigh
According to the information I see, you are correct Conanski! EDIT: Yours is correct like it is!
Ford Part No.: 8C2Z-4602-B
Shaft Assembly - Drive 1 Piece Driveshaft Replaced By 8C2Z-4602-C
https://www.fordpartsgiant.com/parts/ford-shaft-asy-drive_8c2z-4602-b.html?vin=&make=Ford&model=E-150&year=2011&submodel=&extra1=&extra2=&filter=(30 869;36740)
So I searched that part number and came up with these pics.
https://www.tascaparts.com/oem-parts...haft-8c2z4602c
https://www.ebay.com/itm/22370189175...SABEgKtWPD_BwE
Hope that helps..
Anna
Old May 5, 2021 | 07:16 PM
Conanski's Avatar
Conanski
Thanks. The picture in that link looks exactly like mine so I guess it's not backwords. Interesting.
Old May 28, 2021 | 01:33 AM
2000Ford2000's Avatar
2000Ford2000
Mine broke the weld off the rear end coupling. I don't know who welded it but they messed up. Welded it back up quick enough to drive it home but then had to take it to a shop to get it balanced.
meck1
1983 - 2012 Ranger & B-Series
Sep 7, 2018 10:43 PM
occupant
Aerostar
Jun 6, 2005 07:08 PM
I.C. Ford
1978 - 1996 Big Bronco
Aug 26, 2004 10:28 PM
green_6
Bronco II
Sep 11, 2003 09:49 AM
butchf250
Feb 8, 2003 10:10 AM
