Rear Spring U-Bolt
Old May 4, 2021 | 03:52 PM
Danno5's Avatar
Danno5
Rear Spring U-Bolt
So in removing the rear spring u-bolts on my 66 F-100 2wd I bent the end of one side (unless this is how they are supposed to be?), and I cannot find replacements anywhere. Anyone know where I can get these or if another year u-bolt will fit? LCM has 1966 for a F-250, but they told me they are different and would not fit.
thanks in advance!
Dan
Old May 4, 2021 | 04:15 PM
ford390gashog's Avatar
ford390gashog
Those bolts are way past due for replacement. Order them from Dsuban. https://www.dsuban.com/custom-u-bolts/
Also make sure to order the heavy hex nuts and washers at the same time. They ship very fast!
Old May 4, 2021 | 07:05 PM
Danno5's Avatar
Danno5
Thanks! They sure didn't come off easy!
Old May 4, 2021 | 07:56 PM
lizardman1's Avatar
lizardman1
See if you have a spring suspension shop in your area. They could make a set of u-bolts right there. In Phoenix we have Dunbar Spring, they made me a set of u-bolts for a Mustang in about 20 minutes.
Old May 4, 2021 | 08:05 PM
BobbyFord's Avatar
BobbyFord
Summit Racing sells axle u-bolts.
Old May 4, 2021 | 08:15 PM
Christmas's Avatar
Christmas
Napa has them in every size and flavor. Never reuse a U-bolt as the nut crushes the thread when torqued, rendering them one and done.
Old May 4, 2021 | 08:16 PM
john jamieson's Avatar
john jamieson
I don't know the quality, but most auto parts stores have them
Old May 5, 2021 | 07:18 AM
Danno5's Avatar
Danno5
Thanks - I didn't know that! Is that the same for the shackle bolts also? Those came off relatively easily in good condition and I was planning to reuse them....
Old May 5, 2021 | 11:29 AM
Christmas's Avatar
Christmas
Shackle bolts are fine to reuse. They use a special nut that acts like a Nylock.
Old May 6, 2021 | 03:11 PM
dubya TF's Avatar
dubya TF
If you have a store around, O'reilly's carries a bunch of length and thickness u-bolts for around 10-12 bucks each including nuts and washers. That's where I got mine from.
Old May 6, 2021 | 03:36 PM
seventyseven250's Avatar
seventyseven250
This right here. A local spring/axle shop can make then for you for as cheap a anywhere.
Old May 7, 2021 | 08:09 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
If you still end up needing them let me know and I can bend them up and get them shipped to you with free shipping. Normally a 2 day express.
Bvretn1
15
Jun 24, 2024 02:24 PM
64truck
17
Mar 21, 2023 09:05 AM
HAFROD
Mar 2, 2017 09:39 PM
ramracer21
Aug 2, 2008 08:58 PM
Loganwildman
Feb 5, 2005 11:01 PM
