A/C repair
Old May 6, 2021 | 11:48 AM
bwguardian's Avatar
bwguardian
Originally Posted by projectSHO89
That particular dye requires the use of an injector (or having the system completely open.)
Somewhere around here in one of the garages, I have a small can of dye/refrigerant solution. It has a push-on connector that allows a shot of dye to be pushed into a sealed and running system via the low side port. Probably have had it for 10 or 15 years, don't recall which auto parts store I bought it from. If you can still find those, they make it easy to add dye without a lot of fuss.
Found it, it's this stuff: https://www.rechargeac.com/products/...-sealers/UVD-1
I looked at that and according to the reviews the bottle and/or connection seems to break upon installation. This is the reason I was looking at the one I posted as it's in a metal can...like the refrigerant cans...that can be added to the system via a set of manifold gauges.
Old May 6, 2021 | 11:50 AM
bwguardian's Avatar
bwguardian
Originally Posted by 01__Excursion
I was using that as an example, his link was for 1.7 Oz, versus the 1/4 Oz in that little bottle.
Based on the amount he said he's had to add (couple cans, every couple months) he's probably down to just a few PSI anyway.
When I have to add it gets down to 20 psi +- on the low side of course...
James Hogan
Dec 17, 2014 12:57 PM
muddingirl81
Sep 3, 2013 05:30 PM
jimjoebob99
Oct 13, 2009 08:27 AM
lippsenator
Jun 19, 2009 03:02 PM
Riata_Ag
25
Jul 2, 2007 05:32 PM
