Adjustable Track Bar Question
Old May 3, 2021 | 08:25 AM
jiggadog's Avatar
jiggadog
4wd Low
I’m looking at an adjustable track bar, probably a PMF or ReadyLift. From what I understand the PMF can’t be adjusted when installed.
I’ve looked online but it’s not clear to me how does one centre the axle under the truck if the track bar can’t be adjusted when it’s in place?
I have a 1 inch level and DS tire is about 1.5 further out from the frame than PS tire.
Old May 3, 2021 | 08:58 AM
brandon4's Avatar
brandon4
Buy the ICON. I have had it on 16 Ford trucks from '06-'20. Worth every penny. East to adjust on the truck. Has a heim joint too. Very solid.
Old May 3, 2021 | 09:29 AM
4wd6.7L's Avatar
4wd6.7L
Some companies will give you a target measurement to go by based on your lift. Otherwise it might be some trial and error till you get it right. Remove(one end) adjust, reinstall and check. Repeat until good.
Old May 3, 2021 | 11:29 AM
SARDiverDan's Avatar
SARDiverDan
I have a PMF drag link but the track bar is BD Diesel and I pressed out the OEM installed ball joint and pressed in a ball joint from Kryptonite that is greaseable. The whole idea of an adjustable track bar is so it can be adjusted while on the truck. If the PMF can't be adjusted on the truck, there are other options that may work better for you.
Bigblue351
May 23, 2012 11:56 PM
G4mb1t
15
Jun 8, 2010 09:54 PM
JTyler11688
Jan 8, 2009 09:14 AM
69 F100 4x4
Sep 12, 2002 11:40 AM
