Sponsored by: Real Truck
K
Old May 2, 2021 | 01:57 PM
Karen Frederick's Avatar
Karen Frederick
K
I put 285x70x17 on my 99 F250 4x4 7.3 used 2 in spacer. For quick use. I want to buy new rims to run 17 inch tires without spacers don’t trust spacers what will offset be or right measurement. Thanks guys
Old May 3, 2021 | 09:44 AM
bajaphile's Avatar
bajaphile
You'll want a wheel with less backspacing. Assume the factory is ~4.5", you should be looking for a wheel with around 3.00-3.50", which may be difficult, the lower the number, the further they will stick out. Likewise, offset is just a different way of measuring the wheel to mounting surface from the centerline. You'll want negative offset, at least -24mm. That is the issue with the leaf sprung trucks to clear the springs at tight turns.
For what its worth, I have used high quality 2.00" wheel adapters (spacers) without issues. Ensure they are high quality and use proper torque and blue threadlocker on them.
Old May 3, 2021 | 07:37 PM
irydasteelhorse's Avatar
irydasteelhorse
i have a 99, and have run the 285s on factory wheels for years without a single rub. no spacers needed unless youre by chance running later model wheels on it. what gives?
Bigblockboy
Jun 21, 2016 04:59 PM
bossgobbler
Mar 13, 2013 11:16 PM
grapplermi
Nov 24, 2010 02:51 AM
ibminnie4u
Jul 12, 2009 05:06 PM
