1978 vin decoding
Old May 2, 2021 | 08:47 AM
bugsy1955's Avatar
bugsy1955
1978 vin decoding
Hello!
looking for a little help. My son just bought his first vehicle! A Ford truck was what he was looking for and found. It certainly isn’t the original paint, but he plans on enjoying and restoring.
He was told it was a 78 f100, but I believe the vin say it’s a f150.
Can someone help us decode the vin?
thanks!
Old May 2, 2021 | 09:23 AM
Its_Green's Avatar
Its_Green
Should be a '78 F150 2wd with a 302.
Old May 2, 2021 | 09:54 AM
bugsy1955's Avatar
bugsy1955
Thanks for the confirmation! Now just looking for the original color
Old May 2, 2021 | 10:25 AM
440 sixpack's Avatar
440 sixpack
You can tell it's been repainted but the paint under the sticker matches the current color so it's correct. probably light jade metallic , your color code is on the door tag.
Its_Green's Avatar
Its_Green
Do you have the VIN plate on the driver's door? Should have the build codes on it. Failing that a Marti report will give you all that info.
Old May 2, 2021 | 10:42 AM
flowney's Avatar
flowney
The plate on the driver side door is a warranty tag. Because doors can easily be swapped out to deal with collision damage and other issues, one should not rely on it **unless** it corresponds exactly with the VIN stamped on the frame. The VIN stamped on the frame top rail just under where the alternator is found on a V-8 is the only authoritative VIN. There is a second VIN stamping on the frame top rail. It is located below where a passenger would normally sit. Even if you have a title, if the VIN on the title doesn't match what is on the frame, you have a potential problem.
Old May 2, 2021 | 01:22 PM
bugsy1955's Avatar
bugsy1955
Thanks guys! With a lot of elbow grease I confirmed the stamped vin on the frame matches. Will any of the numbers identify the original color?
Old May 2, 2021 | 01:30 PM
Its_Green's Avatar
Its_Green
The VIN itself doesn't help with that unless someone with a database can look it up. But the other plate that would be on the driver's door itself has the color code stamped on it, along with other manufacturing details.
Old May 2, 2021 | 02:09 PM
flowney's Avatar
flowney
Here is the Rosetta Stone for interpreting all the data on the warranty plate:
https://www.fordification.net/tech/vin.htm
The codes can be specific to when the vehicle came off the assembly line so take care to keep that in mind as you navigate the links that provide details such as paint colors and upholstery.
Color code for exterior paint: https://www.fordification.net/tech/vin_extpaint.htm
Old May 2, 2021 | 02:38 PM
bugsy1955's Avatar
bugsy1955
Is this what I was looking for?
Old May 2, 2021 | 02:54 PM
flowney's Avatar
flowney
Yes but yours seems to have been painted over. Here is an annotated image of one:
So H for 1978 translates to Dark Brown Metallic.
Old May 2, 2021 | 05:06 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
In the 2 beers and 5 mins I did this, I might of made a mistake, so double check and or get a Marti report to be 100%.
Born on date May78 so says the Safety Certification sticker (white sticker). And yes the metal door tag is a Warranty tag and NOT a VIN plate. The other one in the engine compartment is a BUCK tag used on the assembly line. Nice truck.
https://www.martiauto.com/martireports.cfm
Series- F15 '75-'79 2 wheel drive pickup (F150)
Motor- G '73-'79 8 302 2-bbl. 5.0 Litre
Assembly plant- N Norfolk
Consecutive unit #- CC7268
Wheel base- 133
Exterior color- H '73 Seapine Green Metallic '76 Medium Copper '77-'79 Dark Brown Metallic
Model F150- '75-'79 F150 2WD Pickup GVW 6050
Body code- ST4 4 Custom cab w/styleside box 81A (exc. Crew Cab) 99
Transmission- G '73-'79 3 Automatic Ford
Axle code 13J '77-'79 2.75 3.75M Ford
GVW- 06050
District code- 24 Jacksonville
Old May 2, 2021 | 06:04 PM
flowney's Avatar
flowney
" 2 beers and 5 mins " ? That's good. I wish I could get that kind of mileage.
Old May 2, 2021 | 06:31 PM
bugsy1955's Avatar
bugsy1955
Thanks everyone for the time and detail! Passed it along to my son and it is amazed and happy. He is picking up a pair of headers from his cousin and is going to start out with adding a duel exhaust (kinda lost the muffler on the 2 hour ride from buying it.)
Thanks again!
Kevin
Old May 2, 2021 | 07:30 PM
77&79F250's Avatar
77&79F250
Make sure to join your FTE state chapter. https://www.ford-trucks.com/forums/forum182/
Depending on your sons age the he might be interested in the 15-25 year age group "Next Generation Forum" here. https://www.ford-trucks.com/forums/forum177/
But he is just as welcome right here.
