Automatic Transmissin Remote Filter
Old Apr 30, 2021 | 10:16 PM
My Ranger's Avatar
My Ranger
2000 LXT 4.0L (X) 4x4 136K
While changing out all fluids I decided to replace original trans pan with new one with drain plug for future changes.
Now I'm thinking of installing a remote transmission filter in the grille next to the cooler.
If I do the remote, can I do away with the original internal trans filter all together ?
That way I only need to replace the spin-on filter up front.
Also, just picked up everything today to drill and install recested 1/4" pipe drain plugs in both the front and rear differentials.
Just finished replacing both valve cover gaskets, all intake manifold gaskets, along with new set of plugs & wires & pcv & fuel filter & oil filter & air filter & new wiper blades.
All oils & gear lube will be Full Syn.
Removed thremostat so I could get better flow through cooling system while running flush solution for a week.
After all this is completed this weekend, engine compartment & under carriage will be power washed.
Interier cleaned & detailed along with the exterier.
I think that may do it for a while.
Any thoughts ?
Old May 1, 2021 | 06:36 AM
DILLARD000's Avatar
DILLARD000
Assuming 5r55e Transmission.
Internal filter case acts as a pickup tube on the bottom side that you can not eliminate.
Also, external ATF cooling loop is not circulating until Tranny temp is >150f;
eliminating internal filter element would allow grit from pan to get into Tranny\Pump\ValveBody; not good.
Would be great to not need to drop pan to change internal filter; hopefully some smarter person has a solution.
berry1234
Jun 25, 2009 10:45 AM
mwsF250
May 5, 2009 09:05 PM
jenkins2
2004 - 2008 F150
Mar 8, 2009 07:28 PM
tlh06f250
6.4L Power Stroke Diesel
Apr 30, 2008 12:13 PM
Stinger_916
Nov 13, 2003 05:29 PM
