1968 F250 4x4 need help decoding
Old Apr 29, 2021 | 06:09 PM
Devv's Avatar
Devv
Hey there I would like some help decoding or figuring out what I'm looking at. The add says 1968 F250 4x4 but the truck has dual rear wheels. Just wondering if they made such a truck in 68 or should this truck have single wheels on the rear. Vin tag Max GVW is 6800lbs. wheelbase is 131. if you need more details I will get the info.
Old Apr 29, 2021 | 06:32 PM
68Flareside240's Avatar
68Flareside240
No DRW until the F350s in the early 80s I think.
Old Apr 29, 2021 | 08:10 PM
fe390pc's Avatar
fe390pc
Either someone installed duals or swapped the rear axle.
Old Apr 29, 2021 | 09:51 PM
Devv's Avatar
Devv
Ya I guess they could have just installed the dual wheels with the original axle. Truck now has a deck on it so my plan was to convert it back to a single wheel truck with a box. Thanks for the help
Old Apr 29, 2021 | 11:41 PM
rwilly1's Avatar
rwilly1
Got a pic?
a dually 4X4 probably looks pretty cool.
Old Apr 30, 2021 | 07:50 AM
Devv's Avatar
Devv
68 F250 4x4
Old Apr 30, 2021 | 07:56 PM
JEFFFAFA's Avatar
JEFFFAFA
There were aftermarket adaptors back then to install dual wheels on a SRW axle.
Old Apr 30, 2021 | 10:12 PM
cbrown9064's Avatar
cbrown9064
Wow! That is a pretty straight truck! Would be interesting to find out if a DRW axle was swapped in, or the adapter kit. At any rate, you should be able to find a SRW D60 pretty easily. Maybe even in the right gear...
Old Apr 30, 2021 | 10:31 PM
rwilly1's Avatar
rwilly1
That’s a beauty!
Old May 1, 2021 | 07:29 PM
fe390pc's Avatar
fe390pc
Great looking ride, I would say that may be a regular axle with duals installed. See if the tag is still on the cover and pull the numbers. I bet ND can say if it's an original.
99hosss
Mar 26, 2012 06:46 AM
kermmydog
May 27, 2007 11:58 PM
ford_nut
Aug 21, 2006 08:57 PM
W1517
Mar 31, 2004 07:02 PM
venom69
Jul 26, 2003 12:23 AM
