Blinking ABS light and loud beeping
Old Apr 29, 2021 | 02:08 PM
Pokey_Whale's Avatar
Pokey_Whale
Just bought a '94 F250 w/ 162K miles, the first fix that has me scratching my head is the blinking ABS light on the cluster and this very loud beeping. I don't know if the two are related. I've driven it about 15-20 minutes and braking felt fine, fluid doesn't appear to be low.
I appreciate any help or suggestions with this matter, I'm new here so can't do private messaging yet.
Thanks all!
Old Apr 29, 2021 | 02:39 PM
jerryparks's Avatar
jerryparks
Count how many times it blinks. I had this happen in my 95 once and it turned out that the brake light fuse was blown and the flashing ABS light was a warning that you have no brake lights. I don't remember the count for it but it's worth checking.
Old Apr 29, 2021 | 03:12 PM
rla2005's Avatar
rla2005
Run the RABS Code Flashout tests
Old Apr 29, 2021 | 10:37 PM
Pokey_Whale
This would make sense! Brake lights illuminate when I turn on headlights, but when I press brake pedal there's no change in brake lights.
Thank you!!!
Old May 2, 2021 | 10:36 AM
Pokey_Whale
It was fuses!!
Hello fellows! I hope everyone is having a good weekend. Just wanted to give an update - I checked all fuses, replaced bad ones, and there is no more flashing ABS light on the cluster. It felt great to fix the first problem and I greatly appreciate the help!!
There is still the loud beeping issue - loud beeps, doesn't seem to be of any consistency, sometimes will beep 4 times then stop for a minute or so but other times will beep 5 or 6 times then stop for a minute or so. There are some lights on the cluster that don't illuminate (so far I've confirmed the right-turn blinker arrow and hazards blinking arrows), and the oil pressure gauge is not functioning (the needle doesn't move). I've changed the oil, checked the dipstick afterwards and volume checks out, there's no oil leaks that I've found yet.
Old May 2, 2021 | 02:11 PM
sandymane's Avatar
sandymane
Your oil pressure gauge is probably the oil pressure sensor, Mine is located behind the upper intake. You just pull the connection off and unscrew the old sensor and replace it. The dash gauge is basically an idiot light and just shows you have pressure of some kind. Some replace the sensor with a sending unit that you connect to a real pressure gauge you install yourself in the truck. I just use the gauge in the truck as I check my oil on a very regular basis.
https://www.oreillyauto.com/search/v...ressure+sensor
Forced347sn95
1997 - 2003 F150
Nov 15, 2008 10:12 AM
Country4.2
1997 - 2003 F150
Jun 12, 2006 09:54 AM
daimon1054
Aug 25, 2004 08:44 PM
