Ford Protect Plan
Old Apr 28, 2021 | 04:36 PM
stbird's Avatar
stbird
Ford Protect Plan
What do you guys think about Ford Protect? I have a 2020 F250 with the 10 speed transmission and 7.3L engine. Do you think getting Ford Protect is a good idea for $3,600. Of the 2 previous Ford trucks I owned neither of them had any issues until well after 10 years. I'm also thinking that if something is a bad design I will find that out in the first 3 years of factory warranty. Thoughts and experiences would be appreciated.
Thanks, Steve
Old Apr 28, 2021 | 04:39 PM
powerboatr's Avatar
powerboatr
my plan was 2600 and some change for ESP with enhanced rental and LED light replacement package 84 months/100k miles 100 deductible
Old Apr 28, 2021 | 04:40 PM
ford390gashog's Avatar
ford390gashog
Thanks, Steve
Well Ford protect has many levels of protection. I would price Lombard Ford , Flood Ford and Zeigler before I purchased.
Old Apr 28, 2021 | 04:42 PM
stbird's Avatar
stbird
I guess my real question is have any of you Ford truck owners had anything major go wrong with your truck between 3 and 8 years of ownership?
Old Apr 28, 2021 | 04:46 PM
ford390gashog
I think you should do a search, there is so many discussions here on this. Some have and some haven't. I have had pretty rough luck on some of my trucks including two full 6.7 replacements in separate trucks after 100k. Both were covered under ESP, so 40k in repair bills covered by 5k in ESP.
Old Apr 28, 2021 | 05:01 PM
dwwright's Avatar
dwwright
I bought the Flood plan for my F150 at 35,000 miles. When I traded it in at $56,000 miles I still hadn't used it. I ended up getting a refund for the premiums. I'll still buy another on the F250 at about 35,000, but just doing the regular maintenance goes a long ways.
Old Apr 28, 2021 | 06:21 PM
chamdaddy's Avatar
chamdaddy
Your truck (and mine) is a first year engine and transmission so the likelihood of an issue is probably statistically higher than the general population of trucks out there. Your quote of $3,600 seems a bit high. The Flood Ford Premium Care plan for 96 months and 100,000 miles with $200 deductible in Maryland is showing $2,060. There is no correct answer to your question, only what is correct for you. My truck has been in service for 11 months and has towed probably 75% of its 7,000 miles and has been near perfect. However, there are many threads out there of those that have been less fortunate with the 2020-7.3L-10sp. With all the electronics on the vehicle, any number of things could short circuit in years 4-8. A failed Sync 3 unit is likely $2,000 or more. I sleep better at night knowing my exposure to any issue over the next 8 years is $200. At the end of the 8 years I won't be thinking of the $2,000 I spent on the ESP even if I have zero issues. I have no buyer's remorse, others will feel the polar opposite and that is okay for them too.
Old Apr 28, 2021 | 06:26 PM
Eddie 500's Avatar
Eddie 500
At least with the gas engines you can do some basic repairs.....those 6.7s you cant fit your fist anywhere under the hood to do anything.....
Old Apr 28, 2021 | 06:58 PM
4wd6.7L's Avatar
4wd6.7L
So is that a yes or a no for the ESP?
Old Apr 28, 2021 | 07:53 PM
Grey SD's Avatar
Grey SD
yes.. from Flood Ford or similar Ford ESP seller, unless your dealer beats or matches the price.
Old Apr 28, 2021 | 09:16 PM
powerboatr's Avatar
powerboatr
well my wifes 2012 edge we bought in 2019, we purchased a 3 year ford esp and it paid for the small price in dec with new struts all around .
it was purchased with only 52k miles on it a real low mile cream puff
Old Apr 29, 2021 | 10:17 AM
stbird's Avatar
stbird
Originally Posted by Grey SD
yes.. from Flood Ford or similar ForESP seller, unless your dealer beats or matches the price.
What is Flood Ford?
Old Apr 29, 2021 | 10:20 AM
chamdaddy's Avatar
chamdaddy
What is Flood Ford?
It is a vendor for Ford ESP plans. There are several others as mentioned above.
https://www.floodfordesp.com/?gclid=...saAmhaEALw_wcB
Old Apr 29, 2021 | 10:38 AM
JeepPuller's Avatar
JeepPuller
I purchased an ESP from Flood Ford 4 years ago when I bought my 2017 F250. It was a first model year with a new transmission (I have the 6.2, so have the 'G' tranny). To date I have not had to use the warranty, but I have piece of mind for another 3 years. Given what recently came to light on the 10spd transmission and the 7.3 being a 'new' motor; I recommend an ESP.
Others say 'bank' the cost and use that for repairs; if you at the end you made no repairs, you still have 2k+ in the bank. Me, I say get the ESP.
Old Apr 29, 2021 | 10:52 AM
stbird's Avatar
stbird
Thanks! How can a dealership sell the same Premium Protect plan for less than Ford Motor Company? Seems a little strange! What are you referring to with the 10 speed transmission?
