I have a 1969 F250. I do have a bench seat out of an F100, but I don't have the sliding adjuster rail that mounts to the floor. Can anyone tell me if there is a repro source for this part, or do I need to look to ebay and the site classifieds?
I would say that's not exactly true. I just put an 87 seat in my 69 F-350 and had to swap the original rails from the 69 seat to make it work. The mounting points under the seat to the rails is exactly the same, but the rails to the cabin floor are not. 69 Rails have four bolts per side and mount flat to the floor. You might be good up through 86 or maybe just 79. I will let others chime on on those. The 87 seat has a turn down on the front that mounts to the rise in the seat pan on those models. It also has only two bolts each side to mount to the floor.
