Wheel well liners or nah?
Old Apr 28, 2021 | 12:23 PM
GM in a Ford's Avatar
GM in a Ford
I ordered my F250 w/o the wheel well liners but wonder if that was smart? I don't them on most trucks on the lot or when I view the inventory online. So they don't seem very popular. I do want to put bigger tires on and thought there would be a chance the liners would get in the way. Should I have gotten them? I assume they can be added later if desired?
Old Apr 28, 2021 | 12:25 PM
Painted Horse's Avatar
Painted Horse
I like them. I think it keeps some of the mud and crap from getting thrown up into the small nooks and crannies
Old Apr 28, 2021 | 12:35 PM
camperfanatic01's Avatar
camperfanatic01
yes they can, i bought them a few weeks later. And they take up very little space so I do not believe you’d have issues with bigger tires….note I only bought the back ones….if you chose to get them advanced auto online has them under the name of Penda Liners for much cheaper, I paid like $85 shipped after a coupon code. Penda is who makes the OEM ones for ford.
Old Apr 28, 2021 | 01:58 PM
67L48's Avatar
67L48
I believe they're a must have that really finishes the truck. They make a huge cosmetic difference. This is a well-traveled topic, so a quick search will bring you to many pictures and discussion of Penda/Advanced Auto that camperfanatic01 mentioned above.
If you believe that 1/16" of plastic is the difference between a tire fitting or not, then I'd suggest you're cutting things way too close and those tires would have problems irrespective of your liner choice.
Old Apr 28, 2021 | 02:04 PM
dwwright's Avatar
dwwright
I like the way they finish the look of the truck, but also keeps crud from getting everywhere under there.
Before
After - Husky liners
Old Apr 28, 2021 | 02:11 PM
GM in a Ford
It isn't the thickness but the shape I was worried about. Whether it would intrude very far into the well and affect larger tires.
Old Apr 28, 2021 | 02:16 PM
sstock1's Avatar
sstock1
No downside to having the liners, keeps the mud kicked up off the tires from messing up the under carriage.
Old Apr 28, 2021 | 02:29 PM
BocaIvan's Avatar
BocaIvan
I have them
As mentioned, finishes the truck off.
Shouldn't be a big deal adding them after.
Joe T's Avatar
Joe T
I like them but on the flip side if you do plan to use the truck offroad a lot they will obstruct your pressure washing of the undercarriage.
Old Apr 28, 2021 | 02:30 PM
GM in a Ford
Seems what I'm finding on Amazon is the rear liners. I believe Ford offered front liners as well which seems like the more important ones. So are you running both front and rear or just one or the other?
Old Apr 28, 2021 | 02:35 PM
ssunit1's Avatar
ssunit1
Agree that liners are the way to go. Not only better look but protects the under side. After market are easy to install.
Old Apr 28, 2021 | 02:37 PM
shawnee1's Avatar
shawnee1
Based on previous threads on wheel liners, the fronts are only available from Ford. There are aftermarket rear liners available for the rear. Penda supplies the rear liners to Ford and are available from Advance Auto shipped to home for around $85 with a coupon code that seems to pop up every time you logged onto their web site. I think rears are more important as more things are exposed in the rear wheel wells. The front already has some covering.
Old Apr 28, 2021 | 04:30 PM
dwwright's Avatar
dwwright
There are OEM front ones. Seems like most of the ford part sites show the rear, but are actually for the front. You may want to verify before ordering. The felt ones that come on them help dampen sound, but the plastics would be easier to wash and more durable.
Old Apr 28, 2021 | 04:39 PM
stbird's Avatar
stbird
I had them on previous trucks and I would never get them again. IMO they produce a rust magnet behind the liner and once salt gets back there, no way to see it or get it out.
Old Apr 28, 2021 | 05:25 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
There's already decent enough ones on the front, so I just went with the rear liners on mine. I like that it gives the truck a more finished look, as well as keeping mud out of places. Another benefit, is protection from rocks thrown from the tires at 40-50+ mph....
