2021 Front Mud Flaps?
Old Apr 27, 2021 | 12:31 PM
bjarnold1's Avatar
bjarnold1
I recently traded in my 2019 RAM 2500 that had AMP power running boards and had a problem with rock chips on the front doors. I had mud flaps installed on the front and that took care of the problem. My new 21 F250 had the factory fixed running boards and was wondering if I should still get the front mud flaps for the new truck or not?
Old Apr 27, 2021 | 12:38 PM
jwc410's Avatar
jwc410
You will want mud flaps or clear bra
Old Apr 27, 2021 | 12:55 PM
powerboatr's Avatar
powerboatr
i installed mud flaps front and rear on my 2016 expedition with folding running boards for the exact same reason
i just ordered front and back for the 2021 f250 sunday
it has fixed boards but the rocks tossed up on them and past the mirrors made my decision very easy, we have high traction asphalt mix here and the small stones are a real pita when they come loose from road surface
i have had great life service from the weather techs, and my neighbor has husky flaps.
i ordered weathertechs
Old Apr 27, 2021 | 01:07 PM
scraprat's Avatar
scraprat
Top Answer: 5
Mud flaps keep alot debris off the step and side of truck. Cheap insurance to add them.
Old Apr 27, 2021 | 01:10 PM
GNR22's Avatar
GNR22
I ordered my '21 F350 without mud flaps but after the first time driving through gravel and watching stones go by my window, and having slush built up all over the side of the truck at the start of winter, I installed some. I opted for the Husky mud flaps. They're pretty good.
Old Apr 27, 2021 | 01:18 PM
ATLScott's Avatar
ATLScott
What low profile flaps do people recommend for the 250's?
Old Apr 27, 2021 | 01:25 PM
scraprat's Avatar
scraprat
Top Answer: 5
Here is the Husky style GNR22 mentioned.
Old Apr 27, 2021 | 02:12 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Optional oem mud flaps are way too expensive, weathertech or husky are much cheaper, and just as good or better.
Old Apr 27, 2021 | 04:08 PM
4wd6.7L's Avatar
4wd6.7L
The OEM aren't much more than the Weathertechs. About $10 more for all 4, depending on where you shop ofcourse. The Husky flaps are the cheapest of the bunch.
Old Apr 27, 2021 | 04:26 PM
Killer-Bimmer's Avatar
Killer-Bimmer
Think the factory flaps look good and they were still wide enough to be effective with 325/60/20’s with +20 offset (rears cover too, just no good pic):
Old Apr 27, 2021 | 04:42 PM
powerboatr's Avatar
powerboatr
yup plain black ones are good priced
the ones with F250 or an emblem are $$ imo
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
If you order them as an option on the truck they are $130 for the set of 4, AFAIK you can get the weathertech for less than $100.
Old Apr 27, 2021 | 04:59 PM
chamdaddy's Avatar
chamdaddy
My Weathertech's were $90 +tax for the set of 4 on Amazon. No drilling and fit perfect. Prior to installation I had road grime slung all over the running boards and up the front doors. They dramatically cut down on the dirt and the rocks that the AT tires like to toss up.
Amazon Amazon
Old Apr 27, 2021 | 05:09 PM
scraprat's Avatar
scraprat
Top Answer: 5
$65.63 for Husky on Amazon (front & rear). These are the one I ordered ignore the "don't fit 2021" they do.
https://www.amazon.com/dp/B01N2SD5V2/ref=cm_sw_r_cp_apa_glt_fabc_MFTCWANCS84356STZVRM?_encoding=UTF8&psc=1 https://www.amazon.com/dp/B01N2SD5V2/ref=cm_sw_r_cp_apa_glt_fabc_MFTCWANCS84356STZVRM?_encoding=UTF8&psc=1
Old Apr 27, 2021 | 06:40 PM
Moof7104's Avatar
Moof7104
Once my truck shows up, I'm thinking about the Rokblokz since it protects alot more. Anyone here have any? One bad thing tho is they cost alot more than Husky.
