Sponsored by: Real Truck
2013 F-250 U0155 CODE
Old Apr 27, 2021 | 03:53 AM
godblessmerica's Avatar
godblessmerica
Hello Everyone,
I have run diagnostics on my tuck and keep getting the code U0155, I tried looking it up and it comes up as an issue with the instrument cluster, however, everything seems to be working fine. Any ideas on how to find out the problem and what might fix it?
Old Apr 27, 2021 | 06:39 AM
projectSHO89's Avatar
projectSHO89
Why are you running diagnostics? Do you have an actual operational issue?
Old Apr 27, 2021 | 12:09 PM
godblessmerica
Sorry if I worded myself unproperly, plugged in the forescan in order to disable the "bulbs out" feature to get rid of hyperlink. Once plugged in forescan reads to see if there are any faulty codes. The only code that comes up is U0155. I looked up the code and it says that it has something to do with the communication within the instrument cluster. I am just curious what it can be and how to fix this code.
Old Apr 27, 2021 | 01:49 PM
projectSHO89
and it reads codes all faulty codes once connected,
I have no idea what that means. Be more explicit. Provide more details...
Old Apr 27, 2021 | 01:52 PM
godblessmerica
Just reworded myself.
Old Apr 27, 2021 | 03:20 PM
projectSHO89
If you don't have any symptoms, just reset it and move on. It may simply be a spurious code from some event in the past.
If it returns, be sure to note which module or sub-system is reporting it.
Old Apr 27, 2021 | 07:00 PM
godblessmerica
I cleared the code, however it keeps coming back, I am attaching a screenshot of what it says.
Old Apr 27, 2021 | 07:23 PM
projectSHO89
If there are no observable symptoms, ignore it.
Old Apr 27, 2021 | 07:25 PM
godblessmerica
Thank you for your help sir.
scarty111
Aug 16, 2013 06:55 PM
JoseFeli
Mar 4, 2011 09:52 PM
jasz41
6.4L Power Stroke Diesel
Dec 13, 2008 01:50 PM
