Exhaust Filter
Old Apr 27, 2021 | 06:11 PM
Vicky Terry Smith's Avatar
Vicky Terry Smith
The invoices say that the DPF is completely plugged and was replaced both times with a new unit. The warning was DPF was full, drive to clean. There was no limp mode, no reduced power, it went down completely and would not restart until I took the pipe apart from the header
Old Apr 27, 2021 | 07:14 PM
kper05's Avatar
kper05
Did you buy this truck new? I'm not convinced this truck is commanding active regenerations properly. Consuming oil was going to be my question too.
Old Apr 27, 2021 | 08:56 PM
Vicky Terry Smith
Yes it had 10 miles on it when we picked it up and it uses no oil. I think you are right about it not letting it regen. I'm hoping 3rd times a charm.
Old Apr 27, 2021 | 11:57 PM
kper05's Avatar
kper05
You should have DTCs for this issue or at least stored ones. If a regen is interrupted and the DPF is still in degraded mode, it's supposed to force another regen at 150 miles. Ask the tech what the active regeneration interval is with your truck. For the 2011 I know it stores the two most recent events so that the PCM can calculate average distance which is also used to determine if there is or isn't an issue. I don't know if it saves more than that though or if Ford configured IDS to lookup the regeneration event value.
It's not looking like a third will fix anything long term based on your experience so far. I doubt they're throwing parts at it though because Ford won't allow the dealer to just replace a $4,500 part without pinpoint testing.
Old Apr 28, 2021 | 09:59 AM
speakerfritz's Avatar
speakerfritz
the regen process requires the vehicle achieves normal operating temp before it starts to regen.....then the regen duration will vary. if you do short trips most of the time...you will never succeed in doing a regen.
cetane boost additives will help reduce soot...soot is what the exhaust filter captures
there is a monitoring tool called forscan and it can be setup to check your DPF regen status.....and it can do what is called an operator commanded regen.
the theoretical automatic regen is 500 miles...if you dirve 500 miles you should check your regen status and if DPF is full...initiate an operator commanded regen.
this regen complexity is one of the things that makes owning a diesel difficult...especially if you do a lot of low speed stop and go driving (metro area driving).
Old Apr 28, 2021 | 05:48 PM
kper05's Avatar
kper05
But the system will be in degraded mode with P24A2 long before it's so plugged the truck won't run, which should also trigger P2463 and P246C (MIL).
Gen1 was 150°F EOT from my experience for a pending active regeneration due to soot load.
slinky_70
6.7L Power Stroke Diesel
29
Jul 6, 2021 04:49 PM
gwg42
15
Mar 17, 2017 07:12 AM
ljutic ss
6.4L Power Stroke Diesel
Dec 3, 2011 09:26 PM
Percys Armory
Nov 9, 2010 09:08 AM
