Steering box sloppy (THAT topic...)
Old Apr 26, 2021 | 04:34 PM
WI Dan's Avatar
WI Dan
I had a reman. LARES steering gear box installed. Didn't change anything in my steering!! UGH.
The wheel is loose/sloppy. It turns 10-15 degrees (maybe more) before any resistance. The pitman arm doesn't move until the resistance is felt.
I reached down and grabbed the input shaft. It turns easily, same as wheel. Between the steering box and steering wheel, all is tight. But I can hear gears slopping in the steering box.
Arrrggghhh....
What should I try next? The allen bolt adjustment?
Ball joints are tight, etc. I've already checked that stuff. It seems all the slop is in the steering gearbox.
(2000 4x4 6.8 V10 Limited)
Old Apr 26, 2021 | 07:35 PM
Cocky EX's Avatar
Cocky EX
I'm not familiar with LARES, I just put in a new Blue Top weekend before last and am very satisfied. No slop at all and the warranty states its void if you do try to make adjustments of any kind. I did a lot of research before deciding on it. The OEM adjustment procedure is located in the tech folder under steering. Did you have it done at a shop that warranties the box and will change it out for another?
Old Apr 27, 2021 | 09:21 AM
WI Dan's Avatar
WI Dan
Part warrantied through RockAuto.
Labor was done by shop. They did well, even fixed a line leak. They won't warranty parts they didn't handle.
Note; my hand-tests were when truck was OFF.
I noticed occassionally when it was running, driving low speeds, it was very responsive. But as I drove more, got up to speed 25mph+ it gets loose again.
could this be problem with power steering hydraulics? Hydroboost system? (I know little about these)
Old Apr 27, 2021 | 09:52 AM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
[QUOTE=WI Dan;19851456
(2000 4x4 6.8 V10 Limited)[/QUOTE]
try taking the vehicle to a shop that specializes in fullsize ford trucks, probably a diesel shop but they should have the know how.
with your description I have my hunch but that is not going to help you and without me driving the vehicle it is just a hunch
the odds of it being the back lash is minimum to not very likely. in other words no don't mess with the backlash screw unless you understand how to set back lash.
fwiw, there is always about 10* of "free play* even when the vehicle was brand new, this is the amount of travel that the torsion spring needs to twist before it modulates the hydraulic portion of the power steering. your "looseness' is likely not the box and to find it takes a complete inspection.
Old Apr 28, 2021 | 08:36 AM
WI Dan's Avatar
WI Dan
Good advice pirate (but not encouraging! lol)
I've been trying to find a good Ford shop nearby but striking out. I'll try diesel shops next.
SNIPER168308
May 14, 2009 05:46 PM
afonda
18
Feb 28, 2009 07:51 AM
Gottaford
Jun 12, 2008 03:13 PM
13MWZ
Nov 24, 2007 05:38 PM
Brats
May 29, 2007 06:10 PM
