start/idle issues
Until recently it would idle down to a low idle and just sit there running slow and easy, no tendency to kill.
Fuel delivery problem? I suppose I could try replacing fuel filter first...
Also possible that some gunk is building up in the injector pump (pump on top of the engine with lines attached). I had a similar problem with my truck shortly after I bought it, most likely because it had been sitting for a while. When I took my foot off the accelerator pedal and hit the clutch, the RPM's would sharply drop and frequently stall before it could settle at idle. If I was slower pulling my foot off it would come to an idle ok.
To fix that, pull the filter off, drain it, then refill with clean ATF. Reinstall the filter. Start the truck and let it run for about 30 seconds, then shut it down. Let sit for a few hours, overnight is best. May have to repeat if it doesn't clear out the first time. The ATF cleans up the deposits that cause parts of the pump to hang up.
To the BalerTwineGuy my first gut reaction was an air leak, tecgod has you in a good direction with the pump. Try filling the tanks up all the way in case you have a cracked pickup tube and check at the filter head for air.
EDIT thinking about it some more generally sucking air makes it run real rough but also take off and run like a raped ape intermittently so less likely.
the diesel kleen is a more diluted method although if I knew I was driving a long distance and going to burn through a tank that day I would try it,
Do you know when you IP was last serviced/rebuilt ?
I would definitely try to the ATF/filter first, then I may hook up a can to the front bump and run your fuel from it (search, there's a good instruction to do this) for a day to see if the problem still exists, at least you know what direction of the fuel supply you need to look at that way,
As for the cleaning abilities of ATF, many have also touted this for cleaning the engine by adding it to the oil. I've seen tests that show ATF to have less cleaning ability than motor oil. I'm not saying that it can't work, but there's a fair amount of evidence against it. Almost everyone I've asked about it cites the cleanliness of transmissions compared to the dirtiness of engines to 'prove' how well ATF cleans. Transmissions aren't exposed to the stuff that engines are, like combustion by-products, that alone crushes the 'proof'.
Some report that ATF helps, some say it did nothing. There have been countless numbers of things that people swore did what they were supposed to do that have been thoroughly debunked. The placebo effect is strong, I've tested it a few times with different products. The vehicle owner always says that the product did exactly as claimed, 'till I show them that I never installed it.
