Leaf springs
I want to pick the *** end of my 88 f150 4x4 about 3-4” and increase load capacity.
No longer have factory box and have increased weight on rear by adding a flat bed.
A set of leafs built to do this sounds like close to a grand. Plus install.
Question... will leafs from a 250 bolt on and give me what I’m looking for ?
Thanks
I've actually done what you're looking for on an '87 F150 long bed. I just added a couple leafs to the existing pack. Works great and inexpensive.
New springs aren't that much. ATS Springs is pretty knowledgeable. Give them a call and see what they recommend. I had all new custom arched Superduty springs made shipped to my door for 388 with all new eye and u bolts.
We have lots of gravel and washboard out here and bouncing into the ditch is a concern.
I’ll shop around a little better, the only game in town around here unless you have an account is pretty pricey.
Aftermarket AAL'S are short and heavily arched in an attempt to provide maximum lift from an inexpensive, easy-to-ship spring. As such they can make ride quality suffer and place odd stress on the pack above.
I've added to packs on 4 OBS Fords, a GMT400, a GMT800 and a GMT355. Never regretted it. About to do a 2nd Gen Ram
so it looks like I have 5 leafs now. I’m guessing that is stock ?
the 5th being the little shorty leaf on bottom of stack.
So I understand correctly, keep my 5 and add 2 more ?
I salvage this from a junkyard or buy some new guys ?
This will give the lift as well as load carry I’m looking for.
The photo above from mudpsort looks like the ride height I’m after.
I'll often cut the spring eyes of another main leaf and throw it right under the main leafs in existing pack(s). Then another maybe under the existing second leaf down. Some of it depends on what the donor packs can provide.
You can totally cut leafs with abrasives, and you can chamfer or taper your cut ends if you want. I wouldn't worry about any factory anti-friction pads that might be there - they're usually plastic and breaking apart by now and I've never missed them.
You'll need new u-bolts from a spring shop (should be $60 to $100 for 4). Get 'em slightly longer than stock to allow for increased pack thickness. And you'd need new u-bolts no matter what, whether replacing entire packs or building a frankenpack.
If building a pack you'll need a longer center pin which is nothing more than a bolt with a round head but often a standard hex head will drop into the spring perch hole. Or you can turn a head round on a belt sander, or use a grinder etc. It doesn't have to be perfectly concentric. Can also shop for a SHCS or of course your spring shop may sell actual center pins, but I've always just made my own.
says I’ve had some previous work done and leafs look good.
They are going to pull apart , re arc the leafs and add 1 more under the top long guy.
Then he said pull the factory horn stop looking deal on top of axle and put a taller block in.
Will not make truck ride bad and will give 2-3” lift in back.
Booked May 07 , I will post up when done with a result.
Appreciate the responses.
Now 6 leafs
I just extend the clamps straight up and leave them open like this - old rockcrawler trick so the leafs can "fan" open at droop
Retained the factory 2" block
Now 6 leafs
The factory stop pulled and a taller one installed.
Hope ride is ok as they assure me it will.
Ill get a pick before and after and will post up.
Thanks
I do have bags, but the leak ever so slow, so i have to keep pumping them up.
Sure it don't help that I have a "light half".
