Make sure that the electrical wire form the alternator is hooked up, and that the hot air tube from the manifold is connected at both ends. Other than that, I suspect that if the larger hot air tube from the manifold to the air filter snorkel is off, that that will negatively impact warm-up as well.
Just piggybacking on this with a topical question. My thermostatic intake never seems to open, so it's always sucking air from the snorkel's air duct. The stove around the manifold is rusted so I'm not sure if it's just not getting hot enough air or do these things malfunction?
No running issues. It's ready to go from the first crank.
