fuel pressure not there
Old Oct 28, 2003 | 08:25 PM
remmers's Avatar
remmers
Before I droped the rear tank It was fine but i droped the rear tank to replace it and now i have no fuel pressure. Both pumps are getting power i am getting power to the relays, but no fuel in the rail?? any ideas. Oh yeah I did run out of gas on the rear tank before i replaced it and i thought i ran out in the frt untill i droped it to replace to float, i wasnt geeting a reading on the frt tank. there was fuel in the frt tank.. I am think a bad filter?? any help woule be great since i havent had the truck out of the garage since i bought it 3 weeks ago
Old Oct 28, 2003 | 10:09 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Can you hear the pump run?
You said you have voltage to the pump, did you check the ground?
Old Oct 28, 2003 | 10:41 PM
remmers's Avatar
remmers
yeah when i turn the key forward i can hear them both engage and i can hear the relay click and i have cked for power to both of them and its there just no fuel making it to the rail
Old Oct 28, 2003 | 11:06 PM
HardScrabble
When you turn the key to the one position, the pump should run for a few seconds, maybe 5 seconds. You can hear the pump run?
Did you put gas in the tank after put it together?
Old Oct 28, 2003 | 11:14 PM
EPNCSU2006's Avatar
EPNCSU2006
Try cycling the switch on and off several times to bleed all the air out of the lines.
Old Oct 29, 2003 | 06:56 AM
remmers's Avatar
remmers
yes i have gas in it i can hear both pumps run and i have tried the fliping the switch trick and that doesnt help
Old Oct 29, 2003 | 08:00 AM
EPNCSU2006's Avatar
EPNCSU2006
Turn the ignition switch on and off several times. Sounds like there's air in the system still. Do you see any leaks?
Old Oct 29, 2003 | 08:16 AM
remmers's Avatar
remmers
no leaks ill try that right now thanks
Old Oct 29, 2003 | 10:26 AM
HardScrabble
Have to turn the switch off for about five seconds each time or the pump will not run.
Old Oct 29, 2003 | 10:28 AM
canarycary's Avatar
canarycary
I didn't see what year truck you're dealing with but is it a possibility that your fuel inertia switch tripped? On my '96 it's located behind the side kick panel on passenger side near the top. My panel has a slight rounded cutout where the switch is located and you can get a finger in there to press the button at the top of the switch to reset. Good Luck!
Old Oct 29, 2003 | 11:07 AM
blue_mule's Avatar
blue_mule
what year is your truck...?
86- 94 i know for sure, yours too probably uses the manual fuel tank selecter valve.
rubber diaphram in switcher goes bad
it uses fuel pressure to switch front to rear, vice versa.
that's why when you flip the switch to front tank no fuel gauge reading.
Old Oct 29, 2003 | 11:14 AM
EPNCSU2006's Avatar
EPNCSU2006
The fuel guages are switched by the selector switch in the dash, so there has to be a bad connection somewhere.
I don't think it's the inertia switch because he said the fuel pumps are running.
Old Oct 29, 2003 | 11:23 AM
stepman's Avatar
stepman
Sounds like a plugged pick-up in the rear tank. If it worked fine,why did you change it? Bad tank? Was new tank the same?
Old Oct 29, 2003 | 12:03 PM
remmers's Avatar
remmers
it is working now i just click the key a fe times
