‘21 Level Kit
Old May 1, 2021 | 07:51 PM
Rwhjr's Avatar
Rwhjr
I’ve ordered the BDS 2” level with Fox shocks
for the rear im going to use a PMF 3.5” rear block.
stock block is 2” on this truck.
Should I order it tapered? If so should I do 2.5° or 5°?
Old May 1, 2021 | 08:01 PM
grngiant's Avatar
grngiant
Same setup that you are thinking of using. 2" BDS level with fox shocks, 1" taller rear block. This is a 2017 6.2 plow package
Old May 1, 2021 | 08:12 PM
Rwhjr's Avatar
Rwhjr
what was the factory rear block height?
I’m trying to figure out if replacing my 2” block with 3.5” block will require me to get one that’s “tapered” or not and to what degree.
Old May 1, 2021 | 08:54 PM
4wd6.7L's Avatar
4wd6.7L
That 17 should have come with a 3" block(actually closer to 3.25").
Old May 2, 2021 | 03:11 AM
grngiant's Avatar
grngiant
factory was 3ish". I used a 4" readylift tapered block.
Old May 3, 2021 | 07:19 AM
mewaschuk's Avatar
mewaschuk
i've got a set ouo adjustable lower spring perch and a set of fox lsc resi from accutune on order for my 20 F350. should be a great riding true leving kit. no plan to run 37s right now and a "2in" level is guaranted to give a nose high stance.
Old May 6, 2021 | 07:21 AM
Rwhjr's Avatar
Rwhjr
Place I’ve ordered a 2 BDS level says over 4weeks until it will ship.
anyone know places online that keep super duty front level kits in stock?
Hoping to get sooner than 4+ weeks
Old May 6, 2021 | 09:47 AM
4wd6.7L's Avatar
4wd6.7L
There are many online sources for that kit. I don't know of many that sell that Adventure series shock with it though. I would do a Google search with that kit part# then contact the vendor to see if they actually have it in stock(unless it says out of stock on their site).
18vtx00
Aug 14, 2020 10:25 AM
Tedorama
Jan 14, 2019 06:18 PM
michaelsmith9391
17
Feb 10, 2011 07:31 PM
allingeneral
Oct 17, 2010 03:37 PM
Powermoon
Jan 16, 2008 12:03 PM
