the horse trailer had a flat, so I took the opportunity to address the bearings that I knew had some slack in them. It’s new to us a couple years ago, so going through the bearings and adjusting the brakes just seemed like good practice. The brakes were definitely not up to par, but worked ok at a higher than expected setting.
so I pull the hub off and the brake shoe falls out onto the ground. So, it needs brakes.
$150/pair on etrailer. Two pair for the whole rig.
I pulled the seals and checked the bearings and the bearings and races looked good. No signs of chipping, or chattering - smooth and shiny.
so I got 4 seals at NAPA -$50 with two tubs of grease. The one inner bearing was found to be $25, so I didn’t inquire further. They were good bearings, though.
Then I hop on etrailer again and I find a wheel kit for $45. Inner and outer bearings, both races, and seals.
normally I wouldn’t hesitate to just repack and use the old bearings. But then I read somewhere that if they are loose, it is because they are worn out. I’ve always just tightened them up and called it good before I read that.
so what would you do? The brakes are a given.
bearings? It adds about $180 to the job, and it would be the last time I ever have to do them. But I may never have to do them again anyway even if I reuse them.
I would be inclined to use the existing bearings, but you are questioning that, so perhaps new is the way to go. I am very big on gut feeling, so go with your gut.
I will caution you about Etrailer though. They are very, very backed up on shipping orders out. I purchased something on the 14th that was in stick with a two day shipping time. After purchase, the estimated shipping date changed to 22 April. Yesterday that date was pushed back to 27 April.
I called them up yesterday and the representative was very nice and told me the warehouse is understaffed and the trucks were lined up for unloading 1/2 mile down the road.
I have used Etrailer many times in the past and will again in the future, but go to another seller if you are looking for the parts quickly.
And now I stand corrected... The parts shipped this morning.
I am in the "know nothing" category though and that is the way I like it. I only present facts and experiences so others can make a decision for themselves.
Etrailer has been and continues to be a good source for parts in my humble opinion.
In my experience, etrailer shipping has been fast until they weren't. At times I found they advertised parts they didn't have and had to come directly from manufacturer, although they did not indicate that until after the order was placed.
I had the same issue on my boat trailer, pulled the drum and the linings fell off the shoe. I took them to a local brake and clutch place and had them relined. I don't remember the cost, but they were riveted on, not glued, and worked excellently after. I got them back in 1 day, hard to beat that with shipping, plus you know they will fit.
I would reuse the bearings.
Only other thing I would consider is (based on what they looked like), taking the drums to a shop and having them trued, machined, and cleaned up. (I mean since you got it apart )
Here is the process I go through on my lawn service trailer which sees a lot of stop and go miles. 3500# axles
I repack the bearings a couple times a year using the easy lube fitting. Annual mileage is 10k so I need new brakes roughly every other year. I pull the hub to check the brakes when I feel they are about time to replace. Pay special attention the hub surface that the magnet rides on. It will become grooved over time and the brakes will chatter as a result. At this point is when I purchase a complete set of backing plates with all new parts already assembled and new hubs which includes new bearings, races, seals, and lug nuts. This is the only time I replace the bearings.
