Sponsored by: Real Truck
4r100 Cooling
Old Apr 20, 2021 | 07:23 PM
ponykilr's Avatar
ponykilr
I recently did the 6.0 cooler on my 7.3. It was not a hard job and went just like the videos and write ups detail.
I got the
Motorcraft 26 row cooler Motorcraft 26 row cooler
, 12’ of
1/2” trans line 1/2” trans line
and the 3/8” to 1/2”
barb adapters barb adapters
for just over $200 from Amazon.
I bought
these clamps these clamps
, they work for both hose sizes and are worlds better than standard worm clamps.
Don’t forget fender washers for the lower cooler mounts.
I plugged the lower hard line while the install was in progress and maybe lost a 1/2 cup total fluid. I only had to add 1qt to get it back to full.
Old Apr 20, 2021 | 07:35 PM
WE3ZS's Avatar
WE3ZS
Originally Posted by Longranger1
@WE3ZS if I was to install the 6.0 cooler or equivalent would I bypass the coolant radiator part or put it inline like the current setup is?
I think the other guys above have you all sorted out and on the right track.
I used the $160-ish Dorman 6.0 32 row cooler on my upgrade, it's an easy upgrade and I did mine at the same time as when I did the complete trans fluid flush.
Old Apr 21, 2021 | 09:55 AM
Longranger1's Avatar
Longranger1
Trailering
Really appreciate all the help guys. I got a motor craft 6.0 cooler on the way and I think all the necessary pieces for the install. Should work good.
Old Apr 21, 2021 | 11:15 AM
Colorado350's Avatar
Colorado350
I installed an inline filter on the hot side aka before the cooler. I replace it once a year regardless of the mileage. My torque converter went out shortly after I installed the 6.0L cooler, that little filter probably saved my new cooler. The filter was packed full of a metallic mush, I wish I had taken pictures of it. I always cut the filter open and inspected to see what kind of debris I’m getting from the transmission. And it’s always this fine metallic mush that the stock filter does not catch that is in the in-line filter. IMO, it’s worth the $20/ year.
https://www.ebay.com/itm/124345655311
Lstanley
Nov 11, 2011 10:10 PM
02GrayPowerStroke
Jan 17, 2008 01:26 PM
someday
Jun 6, 2007 07:59 PM
78xltcrewcab
Apr 30, 2007 01:31 AM
couleeman
Mar 15, 2006 12:02 PM
