C6 speedometer driven gear question
Old Apr 19, 2021 | 05:32 PM
Jeff Wecker's Avatar
Jeff Wecker
I switched from 9.50 16.5" tires, to LT225/75R16 tires on my 1982 E350. Speedometer now reading 5 mph fast. Has a dark green speedometer driven gear on the end of the cable. Are there different gear choices for the cable end? Van also has 4.10 gears.
Old Apr 20, 2021 | 12:33 PM
Mike1's Avatar
Mike1
Maybe this will help you out? https://www.moveras.com/Support/Tool...alculator.aspx
Old Apr 20, 2021 | 04:40 PM
annaleigh's Avatar
annaleigh
I would guess that you have a C6 automatic transmission? If not, which transmission do you have?
Old Apr 20, 2021 | 04:53 PM
Mike1's Avatar
Mike1
I have the AOD, in my 90 E150.
Old Apr 20, 2021 | 06:41 PM
annaleigh's Avatar
annaleigh
DUH, , If i had reread the topic I would have seen he said C6! I think the AOD was used in the econolines from 83 to 93. But what I was trying to find was the number of gears on the output shaft of the C6. The gear that the plastic cable end runs on is made into the output shaft. I am not sure if different years of what vehicle the C6 was used in makes a difference on the output shaft gear. I believe that is called "drive gear:
I used a tire size calculator and it would not let me input the LT but a 225/75R16 tire shows to be 29.3" in diameter. I don't know if the TL would make a difference.
So 4.10 rear end
29.3" tires
And now we need the # of drive teeth on the shaft
Old Apr 20, 2021 | 07:37 PM
Mike1's Avatar
Mike1
The only way I know to count the teeth on the drive gear is to pull the out put tail and count the teeth. Honestly, I haven't messed with a C6 since the 80's I'm not sure you can pull the tail out with out disassembling the whole trans can you?
Old Apr 20, 2021 | 08:37 PM
annaleigh's Avatar
annaleigh
I am not sure Mike1. I have had the tail shaft housing off of my 85 AOD to check the governor and it just basically comes except for the 2 of 4 bolts that broke and the drill bit I broke in one of the broken bolts while trying to get it out! The tail shaft on the C6 also comes off but I am not sure what is involved.
I have some literature with part numbers and will post it in a bit. I haven't learned how to use the book very well so double check any part numbers i post.
i will add it to this post in a bit.
Well this isn't going to help much because it shows the stock 16.5 tires. It is interesting though that the vans came with different gears depending on the tire it came from the factory with. This also verifies that the gear is part of the output shaft.
Old Apr 21, 2021 | 07:29 PM
Jeff Wecker
C6......................
Old Apr 21, 2021 | 07:40 PM
85e150's Avatar
85e150
Take the driven gear out, replace it with one with one more tooth.
Old Apr 21, 2021 | 07:43 PM
Jeff Wecker
Thank you I will try that
harleymsn
Nov 22, 2011 07:19 PM
peterbilttrucker
27
May 3, 2009 02:01 PM
schaad25
Apr 15, 2007 11:03 PM
burnrubba
May 10, 2005 01:51 PM
woods
Jul 29, 2004 02:30 PM
