A/C air flow / cold intermittent
Old Apr 16, 2021 | 08:41 PM
gblinkey's Avatar
gblinkey
I have a 2000 7.3.with a new vacuum pump.
A/C blows cold and hard.
After driving on the interstate for and hour or so, the air flow diminishes and gets warm. The air flow is not being sent to the defrost as the default.
Get off interstate and drive slower and all returns to normal.... cold and blowing hard...
any thoughts????
thanks
Old Apr 17, 2021 | 09:50 AM
alloro's Avatar
alloro
any thoughts?
Any chance the belt is stretched, worn, or slipping?
Old Apr 17, 2021 | 08:35 PM
01__Excursion's Avatar
01__Excursion
Belt or clutch gap may be a factor in the warming part, but the diminished air flow is probably a different issue.
If it's originally blowing hard, than your fan must be set on high ? If so and the air fades away from the dash vents, are you still hearing the fan on high? Their are only 3 locations for the air flow to go. Defrost, dash, and floor.
Old Apr 18, 2021 | 07:17 AM
gblinkey's Avatar
gblinkey
Thanks for the response.
I believe the warming is just coming from the lack of airflow. As far as I know and can tell the fan is still blowing on high.It’s just hard to tell, while driving by yourself ,where the actual airflow went to. I’ll have to do a little better job at diagnosing it when the Airflow disappears the next time.
Thanks again
Old Apr 18, 2021 | 07:24 AM
ToolmakerRob's Avatar
ToolmakerRob
My brother's CCSB F250 had the same issue and we solved it after looking at the gap between the clutch and the AC compressor. We removed one shim, checked the gap and all was well after, good cold AC.
Rob
Old Apr 18, 2021 | 07:33 AM
projectSHO89's Avatar
projectSHO89
The clutch gap cannot cause diminished airflow, only loss of A/C cooling function.
Sounds like the evaporator is icing up.
Old Apr 18, 2021 | 07:41 AM
01__Excursion
^^^, I was heading in that direction...
Old Apr 19, 2021 | 11:08 AM
gblinkey's Avatar
gblinkey
Thanks again for the response,
I believe that is a good possibility that it is the evaporator because the longer I drive the more the air diminishes
What would be the cause of the evaporator to be freezing up?
Thanks again
Old Apr 19, 2021 | 11:23 AM
projectSHO89
The evaporator is too cold and the air passing through it is too humid.
I could be that the refrigerant charge is wrong or the compressor clutch isn't cycling when it's supposed to. On a 2000, it''s likely a cycling switch that has stuck in the closed position.
Old Apr 20, 2021 | 10:58 AM
alloro's Avatar
alloro
All true but lets add a clogged or restricted evaporator drain hose to the list.
Hallworth
1983 - 2012 Ranger & B-Series
Oct 10, 2009 05:09 PM
JesterPgh
Apr 14, 2009 07:06 PM
bax
1997 - 2003 F150
Feb 2, 2004 11:23 PM
brokenvega
Jul 22, 2003 10:37 PM
