Drivers Seat rework
Old Apr 16, 2021 | 06:32 PM
peenhead's Avatar
peenhead
Drivers Seat rework
I have a ‘97 F-250HD and the driver’s seat is about done. Any referrals for a vendor selling new foam cushion, seat back and cloth seat replacement? Thanks
Old Apr 20, 2021 | 10:49 AM
Steve1995 7.3's Avatar
Steve1995 7.3
2nd Gear
I'm hoping someone will respond . I also have a 95 F250 with electric/mechanical drivers seat. The back tilt lever broke off and I also need to have interior done. Maybe I can purchase parts or replacement seat
Old Apr 20, 2021 | 11:17 AM
BuddyBarnes's Avatar
BuddyBarnes
From what I have seen on here and other places , the go to is to get newer seats from bone yard and adapt. I have not seen a vendor . I replaced my cushion on the drivers seat with a new one from a 99-2000, My covers are still in good shape.
Old Apr 21, 2021 | 09:25 AM
oldbird1965's Avatar
oldbird1965
fordman67 has a seat repair procedure, not sure if its in the stickies?
Old Apr 22, 2021 | 12:40 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Buckets can swap foam from side to side. I think the spring box itself was the same too. Been a while since I had them apart, even managed to find replacement lumbar bladders and heated elements for when I redo mine for real. I have seen full bench foam available in LMC. Maybe it could be adapted for the 40/20/40 seats?
I have an '01 Screw here, I can check my bucket foam from the dually and compare it to it as the 01 has buckets too. Might be close enough and that foam is available all over new online and used in JYs.
Material is probably better off for a good upholstery shop...or steal it off of rear seats which are always like new. Gotta think outside the box.
Old Apr 22, 2021 | 05:14 PM
85Supclub's Avatar
85Supclub
You can get replacement upholstery from rock Auto or dash designs. Can totally use passenger foam or the whole passenger seat on the driver's. Just deal with recliner lever in the middle and move lumbar switch.
Buckets and 60/40 seats are different but bolt up. The bucket will sit about an inch taller and little more closer to the wheel. Buckets have more padding it seems. I moved the passenger seat to driver's side and put color match bucket on passenger side with my 60/40. Looks good.
Old Dec 8, 2025 | 08:53 AM
Cowboy34's Avatar
Cowboy34
LMC, NPD National Parts Depot
Also Ebay
Old Dec 8, 2025 | 08:56 AM
Cowboy34's Avatar
Cowboy34
LMC, NPD AND Ebay
arrowheadfred
Aug 30, 2010 09:47 PM
njdan f237d1
1978 - 1996 Big Bronco
Oct 29, 2006 11:57 AM
tjhands
Mar 26, 2003 08:36 AM
