How long does it take for the block heater to warm up a 7.3? I live in Minnesota and was thinking about installing a timer in our garage that would start the heaters about 3 AM giving them about 3-4 hours to warm the block. Our garage isn't heated or inulated but it is attached to the house so temps usually never get below zero with doors closed.
Dan,
I installed a circulatiing block heater on mine that will melt the snow off my hood in about 1 hr. They're nice cause you don't have to have it plugged in for very long (I use a timer on mine) and they will warm up your block enough that so that when you start your engine, you almost instantaneously have heat blowing through your heater. They're fairly inexpensive from most farm supply stores and IMO, they're worth their weight in gold (especially up here in Canada). They do suck back the power when run (I installed a 2000watt unit), but as I said, you only have to run them for about an hour or so (depending on the outside ambient temp). At -30 degrees C, 1 hour is sufficient. Hope this helps!
Rod
Originally posted by 13hondacr250 When it hist -40f we just leave them plugged in all night.
I think I would too! The worst I had in Connecticut last year was about 1 week where we were at or below 0 degrees. Somehow I don't think I'll have that in Texas this year. It's supposed to be in the mid 80's tomorrow.
In Central Washington we only get to maybe 5-15 degrees at night. Is it a bad thing to leave it running all night, other than the additional power drain reflected on my power bill?
I paid $60.00 Canadian for mine from a farm supply store (thats roughly $45.00 US). I don't recall who it is made by, but I do know that it's well made and fairly heavy duty. Hope that helps.
Originally posted by SamMyers In Central Washington we only get to maybe 5-15 degrees at night. Is it a bad thing to leave it running all night, other than the additional power drain reflected on my power bill?
No, go ahead and run it. The element will obviously wear out sooner with more use, but I have no idea how long these things last. At those temps you really don't need it to be plugged in all night. It might be worth it just to buy a timer.
Hey, I have been wanting to put in a circulating block heater too. 1997 f350 cc 4x4 psd. The one I have in my bronco is awesome. higa2000 if your out there I'm a canadian boy as well (alta). What farm store did you go to as we probably have them here too. Thanks for the info
Originally posted by johnsdiesel I think I would too! The worst I had in Connecticut last year was about 1 week where we were at or below 0 degrees. Somehow I don't think I'll have that in Texas this year. It's supposed to be in the mid 80's tomorrow.
if we ever have that kind of weather.....you're diesel not starting won't be your main problem it would be like all the Northerner's die when they have the heat waves of 85. We'd have no water, no food, no roads....life as we know it would end until it hit the mid 20's again.
Hey Ed,
I got my circulating block heater at a United Farmers of Alberta (UFA) store. I just double checked and it is a 1500 watt unit. Good Luck!!
Rod
Hello higa2000, One more question. Which heater hose and where abouts on it did you mount this heater? When I look at my heater hose area there is not much room because of the heater box. Thanks in advance.
Ed,
I have mine mounted on very lowest point on the corner of the front passenger side of the engine (right beside the camshaft position sensor). It's a pretty tight squeeze but it fits. The unit itself sits vertical with about 2-3 " of hose connecting the bottom of it to a coolant drain plug opening (that's right, you have to drain your coolant). Then the outlet is connected with approx. 2-3 ft of hose that runs up until it connects via a "Y" into the return line from the engine block to the heater core (you can recognize the return line as the one that is also connected to the front passenger side of the engine). It's fairly important to mount the unit as low as possible so as to allow the unit to heat the coolant from the lowest part of the engine and allow it to migrate upwards (high school physics - heat rises). Then I have the electrical cord run straight out and through one of the holes in the bumper. I'd post some pictures if I had a digital camera, but I don't. But trust me, it works pretty slick. Hope this helps!
Rod
